Dariusz 25 Posted October 5, 2022 Posted October 5, 2022 So after i did the upgrade to latest version and did a reboot, I am unable to playback videos from this NAS.. I am able to access ones stored on another NAS tho.. i checked al my permissions and they are correct.. jus wondering if anything in this update could have affected it? I attached some logs, one of the videos i was trying was at mat 11:10:27, should be bullet train.. hoping it's something simple. but would be nice to know what the logs show.. thank you ffmpeg-transcode-7e636e3c-1335-4a0b-b0cb-d6af63494efa_1.txt ffmpeg-transcode-7f28edbc-4602-457e-8860-65359884441d_1.txt embyserver (4).txt
Luke 42237 Posted October 5, 2022 Posted October 5, 2022 Could be permission related: :10:27.182 [AVHWDeviceContext @ 0x1155980] libva: /usr/local/AppCentral/emby-server/lib/dri/iHD_drv_video.so init failed 23:10:27.185 /volume1/Media/4K Movies/Bullet Train (2022)/Bullet Train (HEVC AC3 HDR) (WEBDL-2160p).mkv: Permission denied 23:10:27.186
Dariusz 25 Posted October 5, 2022 Author Posted October 5, 2022 5 hours ago, Luke said: Could be permission related: :10:27.182 [AVHWDeviceContext @ 0x1155980] libva: /usr/local/AppCentral/emby-server/lib/dri/iHD_drv_video.so init failed 23:10:27.185 /volume1/Media/4K Movies/Bullet Train (2022)/Bullet Train (HEVC AC3 HDR) (WEBDL-2160p).mkv: Permission denied 23:10:27.186 interesting.. couple days ago I had a firmware update on the NAS as well.. I wonder if something changed with the way permissions are set.. i will have to look into this further.. thank you @Luke for the details 1
Dariusz 25 Posted October 6, 2022 Author Posted October 6, 2022 20 hours ago, Luke said: Let us know what you find. Thanks. well, i got it going, but still not sure what happened.. all permissions were ok, even set it up according to what i have on another NAS which was accessible.. anyways, in end my fix was to disable windows ACL for the folder (it reset everything) and i then tested it works with full permissions.. then i re-enables ACL, setup permissions again and all working.. very strange.. 1
