TeamB 2440 Posted October 4, 2022 Author Posted October 4, 2022 17 minutes ago, Happy2Play said: @TeamB Note if you write nfo files you will need to delete them as identified items will reread the nfo. Only on effected library folder. no nfo files But will my watched status be reset?
Happy2Play 9814 Posted October 4, 2022 Posted October 4, 2022 Just now, TeamB said: no nfo files But will my watched status be reset? Watched/Played can only be lost on items without providerids as we are dependent on original database ids.
TeamB 2440 Posted October 4, 2022 Author Posted October 4, 2022 2 hours ago, Happy2Play said: Note also retested with Adult content enable and still identified via foldername. @TeamBWhat is your system.xml <CollapseVideoFolders> and library options.xml <CollapseSingleItemFolders> values? Also are there any loose items in the \Kid Movies folder? are these switches available from the UI settings anywhere?
Happy2Play 9814 Posted October 4, 2022 Posted October 4, 2022 1 minute ago, TeamB said: are these switches available from the UI settings anywhere? Sorry no and back in 2019 Luke mentioned possible removal but know that would affect a lot of older installs.
TeamB 2440 Posted October 4, 2022 Author Posted October 4, 2022 1 minute ago, Happy2Play said: Sorry no and back in 2019 Luke mentioned possible removal but know that would affect a lot of older installs. so if it was removed what you the value default to (true)?
Happy2Play 9814 Posted October 4, 2022 Posted October 4, 2022 1 minute ago, TeamB said: so if it was removed what you the value default to (true)? Yes if switch is removed it would be collapsed somewhere in the code. But would affect users that do not want a collapse view also. 1
Luke 42301 Posted October 4, 2022 Posted October 4, 2022 19 minutes ago, Happy2Play said: Yes if switch is removed it would be collapsed somewhere in the code. But would affect users that do not want a collapse view also. Nobody should be using it as a personal preference. It is a switch that was added for migration purposes. Anyone using this because they prefer it is relying on something that is not being tested which means anything could happen.
Happy2Play 9814 Posted October 4, 2022 Posted October 4, 2022 @Luke At the same time you have old installs that are configured that way as my original install has most libraries and system.xml that are false. So when/if it ever changes that entire system will rebuild.
