Luke 42239 Posted January 29, 2024 Posted January 29, 2024 Can you try installing our latest USB version and see if that resolves it? https://emby.media/emby-for-samsung-smart-tv.html
SamES 1084 Posted January 29, 2024 Posted January 29, 2024 20 minutes ago, AP123 said: 1.6.4 Thanks, I think the issue has been fixed in the next store release. As Luke has suggested, please test the USB version as that also has the same fix.
waynebird 0 Posted January 30, 2024 Posted January 30, 2024 when will the next store release be available? loading the app with USB seems like a PITA
Luke 42239 Posted January 30, 2024 Posted January 30, 2024 1 hour ago, waynebird said: when will the next store release be available? loading the app with USB seems like a PITA As soon as it gets through Samsung review.
AP123 13 Posted January 30, 2024 Posted January 30, 2024 17 hours ago, SamES said: Thanks, I think the issue has been fixed in the next store release. As Luke has suggested, please test the USB version as that also has the same fix. Thank you for the update. For now I’ve found a work around to extract the ASS file and convert to SRT. I’ll wait for the official app update. I appreciate your response.
SamES 1084 Posted January 30, 2024 Posted January 30, 2024 Did you test the USB version to confirm if it is fixed? If it is not, we may have a different issue that won't be resolved with the store update and needs to be looked at.
