guardianali 13 Posted September 29, 2022 Posted September 29, 2022 (edited) I reinstalled Emby fresh and put all my plugins back. I found my Ytrailers key and enter it. But two issues: 1. When I put the key in and click save, it says "Saved". But when I leave and go back into the plugin, the Key field is not populated. 2. In case that 1 is normal, I then try and run the plugin manually on the Scheduled task screen. It immedietly stops and shows the "ran 1 second ago..." message that naturally counts upward. Enabled debug and log attached. Edited September 30, 2022 by guardianali
Happy2Play 9814 Posted September 29, 2022 Posted September 29, 2022 Believe the plugin dev @radeonwill have to comment on this. 2022-09-29 19:40:33.296 Error App: YTrailers - Error *** Error Report *** Version: 4.8.0.10 Command line: L:\Emby\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19044 Framework: .NET 6.0.9 OS/Process: x64/x64 Runtime: L:/Emby/system/System.Private.CoreLib.dll Processor count: 12 Data path: L:\Emby\programdata Application path: L:\Emby\system System.Net.WebException: System.Net.WebException: The remote server returned an error: (500) Internal Server Error. at System.Net.HttpWebRequest.GetResponse() at YTrailers.Licence.Validate.CheckActivation(String Key) at YTrailers.ScheduledTasks.LocalYTrailersDownloadTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) Source: System.Net.Requests TargetSite: System.Net.WebResponse GetResponse()
Cheesegeezer 3106 Posted September 30, 2022 Posted September 30, 2022 17 hours ago, guardianali said: I reinstalled Emby fresh and put all my plugins back. I found my Ytrailers key and enter it. But two issues: 1. When I put the key in and click save, it says "Saved". But when I leave and go back into the plugin, the Key field is not populated. 2. In case that 1 is normal, I then try and run the plugin manually on the Scheduled task screen. It immedietly stops and shows the "ran 1 second ago..." message that naturally counts upward. Enabled debug and log attached. embyserver (6).txt 96.56 kB · 1 download Your key is saved in that log, so please delete your posted log, the issue is what’s being returned from his server. Let me see if I’m hitting the same issue. are you on beta or release version of emby?
guardianali 13 Posted September 30, 2022 Author Posted September 30, 2022 4 minutes ago, Cheesegeezer said: Your key is saved in that log, so please delete your posted log, the issue is what’s being returned from his server. Let me see if I’m hitting the same issue. are you on beta or release version of emby? I didnt realize it was in there! Ty It seems to now be working. I messeged Radeon on email and soon after it functioned. It may have been an issue on his end. His site and purchase system was down too...
radeon 760 Posted October 1, 2022 Posted October 1, 2022 Having some health issues with my 10 week old daughter so out of the loop for a little while. I will be back soon
Cheesegeezer 3106 Posted October 1, 2022 Posted October 1, 2022 5 hours ago, radeon said: Having some health issues with my 10 week old daughter so out of the loop for a little while. I will be back soon John i wish you all the hope and happiness with her
diaz1510 154 Posted October 2, 2022 Posted October 2, 2022 Figured I'd jump in on the "having issues with YTrailers" as well. @radeon Thanks for everything and hope all goes well. I have a young one as well and it's never pleasant when there's an issue. My issue is slightly different. My License key is populated and stays populated, I just never seem to get any downloads when I run the scheduled task. It just takes 1 second, and doesn't look like anything was downloaded. I sent ya a PM and an email about it, so apologies for the multiple contact routes. Thanks and no hurry, take care of the fam and when you get a chance, let me know if there is anything I need to provide.
Happy2Play 9814 Posted October 2, 2022 Posted October 2, 2022 @diaz1510 Are you getting the same error as above? But dev will probably need to see a server log.
ebr 16346 Posted October 2, 2022 Posted October 2, 2022 19 hours ago, radeon said: Having some health issues with my 10 week old daughter so out of the loop for a little while. I will be back soon Wishing you and your family all the best...
diaz1510 154 Posted October 5, 2022 Posted October 5, 2022 On 10/1/2022 at 6:00 PM, Happy2Play said: @diaz1510 Are you getting the same error as above? But dev will probably need to see a server log. Not getting any errors at all...it just runs through the task in 1 second, and nothing gets downloaded.
Thunder3dan 1 Posted February 26, 2024 Posted February 26, 2024 I just purchased this plugin today. I'm seeing the same thing as above. Task takes 1 second and nothing happens. Maybe I'm using the plugin incorrectly. Also, the license key doesn't save just like the original poster mentioned. I'm assuming it save but you can't really tell.
Luke 42255 Posted February 26, 2024 Posted February 26, 2024 1 hour ago, Thunder3dan said: I just purchased this plugin today. I'm seeing the same thing as above. Task takes 1 second and nothing happens. Maybe I'm using the plugin incorrectly. Also, the license key doesn't save just like the original poster mentioned. I'm assuming it save but you can't really tell. Hi, you may want to pm the server log to The developer @radeon. Thanks
