Super1 16 Posted September 29, 2022 Posted September 29, 2022 I just bought emby pro and now i cant double tap to fast forward 10sec. Why is that better. Oh and it would be a lot better if we could swipe down and up for brightness and volume like on VLC
Luke 42243 Posted September 30, 2022 Posted September 30, 2022 Quote Oh and it would be a lot better if we could swipe down and up for brightness and volume like on VLC Hi, you can do this now in Emby for Android 3.2.75+. It has a brightness slider right on the screen.
Super1 16 Posted October 1, 2022 Author Posted October 1, 2022 21 hours ago, Luke said: Hi, you can do this now in Emby for Android 3.2.75+. It has a brightness slider right on the screen. I have 3.2.77 beta and i dont have the slider on phone app. But i can see the slider if i use tablet
Luke 42243 Posted October 1, 2022 Posted October 1, 2022 Ok yes it's hidden at lower resolutions but maybe we can adjust that threshold a little bit.
Super1 16 Posted October 1, 2022 Author Posted October 1, 2022 2 minutes ago, Luke said: Ok yes it's hidden at lower resolutions but maybe we can adjust that threshold a little bit. Ok great. Currently i am stuck with brightness given. It would be even better if we could swipe down or up any where on the right side of the screen instead of aiming for the bar.
Luke 42243 Posted October 1, 2022 Posted October 1, 2022 2 minutes ago, Super1 said: Ok great. Currently i am stuck with brightness given. It would be even better if we could swipe down or up any where on the right side of the screen instead of aiming for the bar. I know VLC does that but I don't like that. Too many people accidentally trigger it which is what happened to us in the past when we did that.
Super1 16 Posted October 1, 2022 Author Posted October 1, 2022 5 minutes ago, Luke said: I know VLC does that but I don't like that. Too many people accidentally trigger it which is what happened to us in the past when we did that. Ok i understand. I will wait for the update. Good luck and thank you for the help 1
Celsian 7 Posted October 13, 2022 Posted October 13, 2022 (edited) I'm on Emby for Android 3.2.77 on both phones. On Pixel 6 Pro I see the forward, back and pause/play button in the center of the player with brightness control on the right. I prefer this On Pixel 7 Pro I see the forward, back and pause/play button in the lower left corner and no brightness control on the right. I have tried it with the phone's resolution set to 1080 and 1440. Have I missed a setting somewhere in the app or is this a Pixel 7 issue that will be addressed? Edited October 13, 2022 by Celsian
Luke 42243 Posted October 13, 2022 Posted October 13, 2022 Please try again with the next update to the app and let us know how it compares. Thanks. 1
Celsian 7 Posted October 14, 2022 Posted October 14, 2022 I'm sure you meant the update after last night's, but just in case, 3.2.81 is also showing the controls in the lower left corner.
