Guest Posted September 28, 2022 Posted September 28, 2022 I live in Odessa Texas 79765 and we appear to have a number of channels missing from the guide data. I attached screen shots. Is there a process to submit for updates? Thanks! Lee
Luke 42237 Posted September 28, 2022 Posted September 28, 2022 Hi, did you try manually mapping them?
Guest Posted September 28, 2022 Posted September 28, 2022 The same channels are not in the list when I attempt a manual mapping. Thanks for the super quick response. Lee
Guest Posted September 28, 2022 Posted September 28, 2022 Is there an easy way to output that list? It's proving elusive to screen shot
Guest Posted September 28, 2022 Posted September 28, 2022 If it helps the manual list does not contain the matching channel numbers of the missing channels.
Luke 42237 Posted September 28, 2022 Posted September 28, 2022 41 minutes ago, tammyandlee said: If it helps the manual list does not contain the matching channel numbers of the missing channels. Are the channels there, but just without channel numbers, or different numbers?
Luke 42237 Posted September 28, 2022 Posted September 28, 2022 So the channels are not there, or the channel numbers are not there?
Carlo 4561 Posted September 30, 2022 Posted September 30, 2022 You need to manually map them as much of the data is there. I'm looking at the guide data right now. On 9/28/2022 at 11:50 AM, tammyandlee said: I live in Odessa Texas 79765 and we appear to have a number of channels missing from the guide data. I attached screen shots. Is there a process to submit for updates? Thanks! Lee I find all this data in the OTA guide for 79765. You just have to manually map the data as already mentioned.
Guest Posted September 30, 2022 Posted September 30, 2022 That data is still missing the channels highlighted below. It's easier to see it from the hdhome run tuner.
roaku 842 Posted September 30, 2022 Posted September 30, 2022 5 minutes ago, tammyandlee said: That data is still missing the channels highlighted below. It's easier to see it from the hdhome run tuner. Do you actually receive those channels though? My HDHomeRun lists a bunch of channels that are out of market/range and a couple of cable channels like QVC, none of which I can actually tune to. I just hide them.
Guest Posted September 30, 2022 Posted September 30, 2022 I just tried a smattering of them and I can view them even with the blank guide data. If one of them is QVC then Emby is saving me money right now by preventing my wife seeing it in the guide
