Josh8495 0 Posted September 28, 2022 Posted September 28, 2022 Hey, I have an Emby Server on my Unraid System since a few months. I was connecting to it from outside my network via emby connect. I didn't needed port forwarding and enabling UPnP worked perfectly. Yesterday I tried install Wireguard on my Unraid Server and since then, I can't connect to my emby server externaly. I already reinstalled the emby server, deleted wireguard and tried everything in the troubleshooting section. canyouseeme shows the IP address, which the emby server shows me, but I can't connect to both emby ports. Do you guys have any idea how to fix this problem? Josh
Neminem 1623 Posted September 28, 2022 Posted September 28, 2022 (edited) I would ask in the Unraid forum. Since you enabled wireguard in the Unraid server. And now you have trouble. I guess that enabled a new network layer on your Unraid server, that broke your docker network. Try with manual port forwarding in you router. Just a guess. Edited September 28, 2022 by jaycedk
Luke 42245 Posted September 28, 2022 Posted September 28, 2022 59 minutes ago, Josh8495 said: Hey, I have an Emby Server on my Unraid System since a few months. I was connecting to it from outside my network via emby connect. I didn't needed port forwarding and enabling UPnP worked perfectly. Yesterday I tried install Wireguard on my Unraid Server and since then, I can't connect to my emby server externaly. I already reinstalled the emby server, deleted wireguard and tried everything in the troubleshooting section. canyouseeme shows the IP address, which the emby server shows me, but I can't connect to both emby ports. Do you guys have any idea how to fix this problem? Josh HI, perhaps try setting up port forwarding manually in your router?
Josh8495 0 Posted September 29, 2022 Author Posted September 29, 2022 Yes, I tried it, but it won't work. I guess, I have to do a fresh install on unraid.
Luke 42245 Posted September 29, 2022 Posted September 29, 2022 5 hours ago, Josh8495 said: Yes, I tried it, but it won't work. I guess, I have to do a fresh install on unraid. I'm not sure that will make a difference. What exactly did you configure in your router?
