Taurec 60 Posted September 27, 2022 Posted September 27, 2022 hello people, it would be great if someone could help me. How can I find out which film is missing in my Emby library. Example: In Emby I have 3000 movies in my folder structure I have 3010 movies (Each movie is in its own folder) For series the same. I am missing 8 entries. Does anyone have an idea how I can find out which entries are missing from Emby. Greetings Taurec
Happy2Play 9800 Posted September 27, 2022 Posted September 27, 2022 @Taurec Are you "grouping into collections"? Does Folder view provide the same count?
Taurec 60 Posted September 27, 2022 Author Posted September 27, 2022 @Happy2Play i doesnt group anything. The no. of items are the number when i open my movie or any other bibliothek (at the top of the library) its doesn't matter witch kind of library. I miss around 10-15 Items per Library.. How i can find out witch one cu Taurec
Luke 42186 Posted September 27, 2022 Posted September 27, 2022 Can you show a screenshot example? Thanks.
Taurec 60 Posted September 28, 2022 Author Posted September 28, 2022 Hi, sorry for late response.. Please take a look, Emby Movies: for Shows there are 686 folders, Emby show only 685 Entries Emby Doku (mixed Content for mixed content there are 2556 folders, Emby show only 2547 Entries Emby Shows: for schows there are 2717 folders , emby schow only 2698 Entrys All Movies, shows or what ever has a own folder. Do you have a suggestion how I can find out which entries are missing? cu Taurec
Luke 42186 Posted September 28, 2022 Posted September 28, 2022 14 hours ago, Taurec said: Hi, sorry for late response.. Please take a look, Emby Movies: for Shows there are 686 folders, Emby show only 685 Entries Emby Doku (mixed Content for mixed content there are 2556 folders, Emby show only 2547 Entries Emby Shows: for schows there are 2717 folders , emby schow only 2698 Entrys All Movies, shows or what ever has a own folder. Do you have a suggestion how I can find out which entries are missing? cu Taurec Filter settings View settings Parental control or user access restrictions Content mis-identified with incorrect internet metadata (try eyeballing your list for something you don't recognize).
visproduction 328 Posted September 28, 2022 Posted September 28, 2022 I would run a dir command from Windows shell when you are in each library. dir /b > folders.txt dir /b /s *.mp4, *.mkv > media_content.txt Then copy paste folder.txt into Excel or spreadsheet program in column A and copy paste media_content.txt into column B. Where the rows show a folder in column A but nothing in Column B, then that is your missing content. 1
