HeroLeam 11 Posted September 27, 2022 Posted September 27, 2022 (edited) for a while now it's not been pulling data from myanimelist anymore, so much plot, episodes, images, nothing, in the past I usually identify, after having some updates of the plugs that spoiled... Can you see why it doesn't work anymore? embyserver.txt Edited September 27, 2022 by HeroLeam
Happy2Play 9814 Posted September 27, 2022 Posted September 27, 2022 If this is about images, what is your image provider order? From the log it would suggest FanArt.tv is first provider. 2022-09-26 22:32:21.958 Info HttpClient: GET https://assets.fanart.tv/fanart/tv/79824/tvposter/naruto-shippuuden-540233a15a443.jpg Identify will show the Metadata download image but images will actually be gotten from your library setup image order. Possibly changing in the near future as this has been discussed in several topic, why am I getting a different image then presented on Identify.
HeroLeam 11 Posted September 27, 2022 Author Posted September 27, 2022 2 hours ago, Happy2Play said: If this is about images, what is your image provider order? From the log it would suggest FanArt.tv is first provider. 2022-09-26 22:32:21.958 Info HttpClient: GET https://assets.fanart.tv/fanart/tv/79824/tvposter/naruto-shippuuden-540233a15a443.jpg Identify will show the Metadata download image but images will actually be gotten from your library setup image order. Possibly changing in the near future as this has been discussed in several topic, why am I getting a different image then presented on Identify. myanimelist is the first...
Happy2Play 9814 Posted September 27, 2022 Posted September 27, 2022 @Lukewill have to comment but no images are returned.
Happy2Play 9814 Posted September 27, 2022 Posted September 27, 2022 (edited) Testing this from Identify I get this 2022-09-27 03:51:09.513 Debug App: Running MyAnimeListSeriesImageProvider for C:\Users\Media\Desktop\Videos\Unset\Naruto Shippūden 2022-09-27 03:51:09.514 Error ProviderManager: MyAnimeListSeriesImageProvider failed in GetImageInfos for type Series *** Error Report *** Version: 4.8.0.9 Command line: C:\Users\Media\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.25206 Framework: .NET 6.0.9 OS/Process: x64/x64 Runtime: C:/Users/Media/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\Media\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Media\AppData\Roaming\Emby-Server\system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Plugins.MyAnimeList.Api.WebRequestAPI(String link, CancellationToken cancellationToken, String name, String pw) at Emby.Plugins.MyAnimeList.MyAnimeListSeriesImageProvider.GetImages(String aid, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken, IRemoteImageProvider provider, IDirectoryService directoryService, Int32 providerIndex) Source: Emby.Plugins.MyAnimeList TargetSite: Void MoveNext() 2022-09-27 03:51:09.514 Debug App: Running FanartSeriesProvider for C:\Users\Media\Desktop\Videos\Unset\Naruto Shippūden 2022-09-27 03:51:09.515 Info HttpClient: GET https://assets.fanart.tv/fanart/tv/79824/tvposter/naruto-shippuuden-540233a15a443.jpg Edited September 27, 2022 by Happy2Play
HeroLeam 11 Posted September 27, 2022 Author Posted September 27, 2022 12 minutes ago, Happy2Play said: @Lukewill have to comment but no images are returned. Exactly, I turned off all the others, I left only myanimelist, so it doesn't search for any images...
HeroLeam 11 Posted September 27, 2022 Author Posted September 27, 2022 @Luke @Happy2Play the series metadata doesn't fetch either, even though myanimelist is the first
Happy2Play 9814 Posted September 27, 2022 Posted September 27, 2022 3 minutes ago, HeroLeam said: Exactly, I turned off all the others, I left only myanimelist, so it doesn't search for any images... It searches and provides same error as above for me. So I can see that error every time I go to edit image and select that provider. 2022-09-27 04:04:12.076 Debug Server: http/1.1 GET http://localhost:8096/emby/Items/3218/RemoteImages?Type=Primary&ProviderName=MyAnimeList&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Microsoft Edge Windows&X-Emby-Device-Id=de4cdc9f-6819-45f4-b554-f362d3e4a6a0&X-Emby-Client-Version=4.8.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36 Edg/105.0.1343.50 2022-09-27 04:04:12.078 Error ProviderManager: MyAnimeListSeriesImageProvider failed in GetImageInfos for type Series *** Error Report *** Version: 4.8.0.9 Command line: C:\Users\Media\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.25206 Framework: .NET 6.0.9 OS/Process: x64/x64 Runtime: C:/Users/Media/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\Media\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Media\AppData\Roaming\Emby-Server\system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Plugins.MyAnimeList.Api.WebRequestAPI(String link, CancellationToken cancellationToken, String name, String pw) at Emby.Plugins.MyAnimeList.MyAnimeListSeriesImageProvider.GetImages(String aid, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken, IRemoteImageProvider provider, IDirectoryService directoryService, Int32 providerIndex) Source: Emby.Plugins.MyAnimeList TargetSite: Void MoveNext() 2022-09-27 04:04:12.078 Debug Server: http/1.1 Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/Items/3218/RemoteImages?Type=Primary&ProviderName=MyAnimeList&Limit=50&X-Emby-Client=Emby
HeroLeam 11 Posted September 27, 2022 Author Posted September 27, 2022 (edited) @Luke @Happy2Play if I leave only the myanimelist plugin does not search for anything, I need to leave the anime plugin also to search for something. Edited September 27, 2022 by HeroLeam
Happy2Play 9814 Posted September 27, 2022 Posted September 27, 2022 Dev will have to comment as I really can't see anything in the log on what it is doing and don't see any cached metadata like other providers api calls.
Luke 42288 Posted September 27, 2022 Posted September 27, 2022 10 hours ago, Happy2Play said: Dev will have to comment as I really can't see anything in the log on what it is doing and don't see any cached metadata like other providers api calls. Did you supply a username and password in the plugin settings, or leave them blank (leaving them blank is OK).
Happy2Play 9814 Posted September 27, 2022 Posted September 27, 2022 5 minutes ago, Luke said: Did you supply a username and password in the plugin settings, or leave them blank (leaving them blank is OK). Left it blank.
Happy2Play 9814 Posted September 28, 2022 Posted September 28, 2022 Plugin update resolved image issue. But honestly do not know what metadata comes from this provider. 2022-09-27 18:06:47.956 Debug App: Running MyAnimeListSeriesImageProvider for C:\Users\Media\Desktop\Videos\Unset\Naruto Shippūden 2022-09-27 18:06:47.956 Info HttpClient: GET https://myanimelist.net/anime/1735 2022-09-27 18:06:48.671 Info HttpClient: GET https://cdn.myanimelist.net/images/anime/1565/111305.jpg 2022-09-27 18:06:48.693 Debug ProviderManager: Saving image to C:\Users\Media\Desktop\Videos\Unset\Naruto Shippūden\folder.jpg 1
HeroLeam 11 Posted September 28, 2022 Author Posted September 28, 2022 9 hours ago, Happy2Play said: Plugin update resolved image issue. But honestly do not know what metadata comes from this provider. 2022-09-27 18:06:47.956 Debug App: Running MyAnimeListSeriesImageProvider for C:\Users\Media\Desktop\Videos\Unset\Naruto Shippūden 2022-09-27 18:06:47.956 Info HttpClient: GET https://myanimelist.net/anime/1735 2022-09-27 18:06:48.671 Info HttpClient: GET https://cdn.myanimelist.net/images/anime/1565/111305.jpg 2022-09-27 18:06:48.693 Debug ProviderManager: Saving image to C:\Users\Media\Desktop\Videos\Unset\Naruto Shippūden\folder.jpg yes, the image is now fetching, but the metadata is fetching from somewhere else, because the title and synopsis is coming different from what is in myanimelist...
Luke 42288 Posted September 28, 2022 Posted September 28, 2022 7 hours ago, HeroLeam said: yes, the image is now fetching, but the metadata is fetching from somewhere else, because the title and synopsis is coming different from what is in myanimelist... Maybe MovieDb or Tvdb?
HeroLeam 11 Posted September 28, 2022 Author Posted September 28, 2022 (edited) 3 hours ago, Luke said: Maybe MovieDb or Tvdb? ok, but if I put it to identify by myanimelist why doesn't it prioritize? this is the problem I'm reporting, when the plugin was just one, it was looking for the information normally, after the anime metadata was dismembered, there's this confusion... Edited September 28, 2022 by HeroLeam
Happy2Play 9814 Posted September 28, 2022 Posted September 28, 2022 Honest don't believe the plugin itself does not provide much. MediaBrowser/Emby.Plugins.MyAnimeList (github.com)
Happy2Play 9814 Posted September 28, 2022 Posted September 28, 2022 (edited) Don't know scrapers but assume html change. As it appear to be <p> not <span>. /// <summary> /// WebContent API call to get the description /// </summary> /// <param name="WebContent"></param> /// <returns></returns> public string Get_OverviewAsync(string WebContent) { return WebUtility.HtmlDecode(One_line_regex(new Regex("<span itemprop=\"description\">(?s)(.+?)</span>"), WebContent)); } But this is a community plugin for anyone that know what to do. Devs try to maintain but can't to everything. Edited September 28, 2022 by Happy2Play 1
Happy2Play 9814 Posted September 28, 2022 Posted September 28, 2022 Will guess the same for Title But this is a community plugin for anyone that know what to do. Devs try to maintain but can't to everything.
HeroLeam 11 Posted September 29, 2022 Author Posted September 29, 2022 1 hour ago, Happy2Play said: Will guess the same for Title But this is a community plugin for anyone that know what to do. Devs try to maintain but can't to everything. but I installed the plugin directly through emby in catalag, I didn't download it from github, do you think I should use it from github? or is it the same that is already in emby?
Happy2Play 9814 Posted September 29, 2022 Posted September 29, 2022 @HeroLeam The plugin is created from the code on github. This plugin was not built by Emby dev originally that I know of, and Luke has done what he can to keep it compatible but has not modified original code that appears to be wrong or outdated. But without community support to update or Emby Dev has time to look at, I see the plugin possibly just stopping to work.
Happy2Play 9814 Posted September 29, 2022 Posted September 29, 2022 (edited) Not sure if there is a lookup issue also. Identify by Name provides no results either. 2022-09-28 17:39:31.861 Info HttpClient: GET https://myanimelist.net/search/all?q=Naruto Shippuden 2022-09-28 17:39:32.402 Debug App: MyAnimeListSeriesProvider returned no metadata for C:\Users\Media\Desktop\Videos\Anime\Naruto Shippuden Searching by name needs to be "Naruto Shippuuden" Identified by providerid 1735. @Luke changing span to p resolves Description issue. MediaBrowser/Emby.Plugins.MyAnimeList (github.com) return WebUtility.HtmlDecode(One_line_regex(new Regex("<p itemprop=\"description\">(?s)(.+?)</p>"), WebContent)); Still looking at Title as I have not gotten it to work. Edited September 29, 2022 by Happy2Play
HeroLeam 11 Posted October 9, 2022 Author Posted October 9, 2022 On 9/28/2022 at 10:35 PM, Happy2Play said: Not sure if there is a lookup issue also. Identify by Name provides no results either. 2022-09-28 17:39:31.861 Info HttpClient: GET https://myanimelist.net/search/all?q=Naruto Shippuden 2022-09-28 17:39:32.402 Debug App: MyAnimeListSeriesProvider returned no metadata for C:\Users\Media\Desktop\Videos\Anime\Naruto Shippuden Searching by name needs to be "Naruto Shippuuden" Identified by providerid 1735. @Luke changing span to p resolves Description issue. MediaBrowser/Emby.Plugins.MyAnimeList (github.com) return WebUtility.HtmlDecode(One_line_regex(new Regex("<p itemprop=\"description\">(?s)(.+?)</p>"), WebContent)); Still looking at Title as I have not gotten it to work. This is bad, because I like other people who use emby and watch anime will feel frustrated by the fact that they don't have the necessary support, it would be the same as not continuing the imdb plugin, which is the biggest movie metadata.
Luke 42288 Posted October 9, 2022 Posted October 9, 2022 Have you noticed the improvements with the latest update to the plugin?
