sngreco 1 Posted September 25, 2022 Posted September 25, 2022 I know IPTV m3u files change frequently, so I'm sure it's something related to that. I'm trying to figure out what Emby uses in the m3u file to track it. Is it the URL? Channel name? etc.
Spaceboy 2573 Posted September 25, 2022 Posted September 25, 2022 tvg-name the solution for this has been coded in the unreleased emby live tv beta...
sngreco 1 Posted September 25, 2022 Author Posted September 25, 2022 7 minutes ago, Spaceboy said: tvg-name the solution for this has been coded in the unreleased emby live tv beta... Do you have any details I can read about how they solved it?
sngreco 1 Posted September 26, 2022 Author Posted September 26, 2022 2 hours ago, Luke said: It's tvg-id actually. Do you agree that it's fixed in a beta release? If yes, can you point me to any documentation on it?
Luke 42186 Posted September 27, 2022 Posted September 27, 2022 On 9/25/2022 at 8:48 PM, sngreco said: Do you agree that it's fixed in a beta release? If yes, can you point me to any documentation on it? Hi, can you please describe a specific example of your issue? Thanks.
