Luke 42235 Posted February 5, 2023 Posted February 5, 2023 3 hours ago, mvbwbv said: Hi Luke Yes Emby Live TV setup shows only 1 tuner and will play 1 program. I have tried removing both Wintv10 and Emby then reinstalling. WinTV will play 2 instances so different channels at the same time but Emby will not. Please can you assist with this? Hi, we are looking into this. Thanks.
mvbwbv 0 Posted February 6, 2023 Author Posted February 6, 2023 Hi Luke Is this a known issue ? Regards Mark
Luke 42235 Posted February 6, 2023 Posted February 6, 2023 5 hours ago, mvbwbv said: Hi Luke Is this a known issue ? Regards Mark For the second hauppauge tuner yes we are looking into it.
mvbwbv 0 Posted February 6, 2023 Author Posted February 6, 2023 So to confirm I have 1 WinTV DualHD tuner which should give 2 simultaneous channels but only now shows 1 under TV source where it use to show 2.
Luke 42235 Posted February 14, 2023 Posted February 14, 2023 On 2/6/2023 at 1:07 PM, mvbwbv said: So to confirm I have 1 WinTV DualHD tuner which should give 2 simultaneous channels but only now shows 1 under TV source where it use to show 2. HI, yes we're looking into it. Thanks.
mvbwbv 0 Posted February 26, 2023 Author Posted February 26, 2023 Hi Luke, Is there any update on this? I have set up a spare Win7 PC and installed WinTV, the USB device, and emby from scratch and still only see one tuner and can only watch one channel. I have tried playing with NextPVR, but not totally sure what to do with it as there are no instructions or options.
mvbwbv 0 Posted March 7, 2023 Author Posted March 7, 2023 Is there any update on this? could a Beta version help?
Luke 42235 Posted March 8, 2023 Posted March 8, 2023 On 3/7/2023 at 2:08 PM, mvbwbv said: Is there any update on this? could a Beta version help? Hi, can you try restarting the app and let me know if you're still seeing this? Thanks.
mvbwbv 0 Posted March 9, 2023 Author Posted March 9, 2023 Hi Luke, I have restared the emby server and tried to add a 2nd tuner but still not showing up. Version 4.7.11.0
Luke 42235 Posted March 9, 2023 Posted March 9, 2023 3 hours ago, mvbwbv said: Hi Luke, I have restared the emby server and tried to add a 2nd tuner but still not showing up. Version 4.7.11.0 HI, so this is about a different problem now? The tuner is not showing up where exactly?
mvbwbv 0 Posted March 9, 2023 Author Posted March 9, 2023 sorry, not trying to be rude but could you read the previous posts above.
Luke 42235 Posted March 9, 2023 Posted March 9, 2023 19 minutes ago, mvbwbv said: sorry, not trying to be rude but could you read the previous posts above. I did, but where exactly is the tuner not showing up?
mvbwbv 0 Posted March 9, 2023 Author Posted March 9, 2023 ok, under Live TV, Add TV source there is only 1 WinTVdual HD source showing where there used to be 2. It will not detect a second source.
Luke 42235 Posted April 17, 2023 Posted April 17, 2023 On 3/9/2023 at 2:32 PM, mvbwbv said: ok, under Live TV, Add TV source there is only 1 WinTVdual HD source showing where there used to be 2. It will not detect a second source. Hi, for Hauppauge I believe the issues are resolved in the 4.8 server beta channel. If you need immediate relief you might consider trying that. Just please make sure to browse the testing area first to get a feel for open issues and whether or not they'll be a problem for you. Thanks.
mvbwbv 0 Posted June 7, 2023 Author Posted June 7, 2023 Any update on this? I have seen emby has updated a few times now on 4.7.13.0 but still not sorted.
mvbwbv 0 Posted August 19, 2023 Author Posted August 19, 2023 Still the same issue as January any suggestion if this will ever be addressed?
Luke 42235 Posted September 7, 2023 Posted September 7, 2023 On 8/19/2023 at 3:21 AM, mvbwbv said: Still the same issue as January any suggestion if this will ever be addressed? Hi, what version of the app and server are you on now?
mvbwbv 0 Posted September 7, 2023 Author Posted September 7, 2023 version 4.7.14.0 To confirm we are talking about under Live TV, Add TV source there is only 1 WinTVdual HD source showing where there used to be 2. It will not detect a second source.
Luke 42235 Posted September 14, 2023 Posted September 14, 2023 Quote It will not detect a second source. If it's one device with two tuners then you'll only see one there.
mvbwbv 0 Posted September 15, 2023 Author Posted September 15, 2023 (edited) previously there were 2 sources showing and you could record 1 and watch a second. it is a dual tuner device. Edited September 15, 2023 by mvbwbv
Luke 42235 Posted September 16, 2023 Posted September 16, 2023 On 9/15/2023 at 4:02 AM, mvbwbv said: previously there were 2 sources showing and you could record 1 and watch a second. it is a dual tuner device. It should only be one entry in Emby live tv setup, but you can still use both tuners. I believe there is an issue with this with Hauppauge and the 4.7 server release, but this has been corrected in the upcoming 4.8 release. One entry in live tv setup, and use of both tuners.
mvbwbv 0 Posted December 10, 2023 Author Posted December 10, 2023 Please can you advise when 4.8 will released. This issue has now been raised for over a year. Seeming the dual tuner worked previously and was broken by the latest release, please can this be fixed.
Luke 42235 Posted December 10, 2023 Posted December 10, 2023 Hi, should be soon. We're working hard on it. Thanks.
