Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 1 minute ago, Dickydodah! said: I can confirm that removing and running SubKiller again before re adding the SRT files works. I can also confirm that refreshing the processed list is what causes the problem. Yup, lets set some time aside tomorrow if you're available to smash out these couple of bugs. you probably have a list, so we can make this robust and hopefully fire and forget.
Dickydodah! 154 Posted October 28, 2022 Posted October 28, 2022 I went back to basics and tried to narrow down the weird behaviour and came up with this. I think a fair few other issues were probably linked to this so one step at a time I reckon I should be able to test most of the day tomorrow. 1
Dickydodah! 154 Posted October 29, 2022 Posted October 29, 2022 Morning, I've been digging a bit deeper and I see that you are using Emby MediaStreams to identify the subs. It looks like you need to check the external flag as that will allow you to skip already extracted or downloaded subs. You probably already knew this
Cheesegeezer 3106 Posted October 29, 2022 Author Posted October 29, 2022 1 hour ago, Dickydodah! said: Morning, I've been digging a bit deeper and I see that you are using Emby MediaStreams to identify the subs. It looks like you need to check the external flag as that will allow you to skip already extracted or downloaded subs. You probably already knew this what if the user downloads subs from subscene when new media is added. This would leave all of the internal subs still stored in the container. So we still have to check if the item has subs.
Dickydodah! 154 Posted October 29, 2022 Posted October 29, 2022 (edited) Agreed, my point is we have to differentiate between embedded and external as at the moment SK is trying to process external on a refresh which then continually loops everytime SK runs. Edited October 29, 2022 by Dickydodah!
Cheesegeezer 3106 Posted October 29, 2022 Author Posted October 29, 2022 20 minutes ago, Dickydodah! said: Agreed, my point is we have to differentiate between embedded and external as at the moment SK is trying to process external on a refresh which then continually loops everytime SK runs. oh right i'm with you, i didn't get what the issue was. I think there is a flag for IsExternal. i'll have a wee look see
Dickydodah! 154 Posted October 29, 2022 Posted October 29, 2022 If it helps Emby seems to show SUBRIP as the codec for embedded subs and SRT for external SRT sub files (unsurprisingly) with external YES for SUBRIP and External NO for SRT. I'm not sure what other text based subs will show as ATM but currently that's not the issue. DVBSUB and eia_608 both show as external NO but they are graphical subs so not in the scope of SubKiller 1
Cheesegeezer 3106 Posted October 31, 2022 Author Posted October 31, 2022 Will be looking at making the improvements tomorrow. Any helpers/testers are welcome 1
Medic97 4 Posted December 6, 2022 Posted December 6, 2022 What happens to the files that get extracted. Do they get moved to a folder for review and up to me to delete or are they deleted outright? Either option is ok with me I just don't want to files getting lost on my NAS. Do you have a newer version you need tested? Going to try it on a new library.
Dickydodah! 154 Posted December 6, 2022 Posted December 6, 2022 I'm pretty sure they are deleted. If you want to review them just tick all the languages you want and they should all be extracted and you can then delete the ones you don't want, or just leave them in the folder with the video file.
Medic97 4 Posted December 6, 2022 Posted December 6, 2022 I ran it twice and each time it did nothing. What setting do I need to remove all these besides english. I have english selected already.
Dickydodah! 154 Posted December 6, 2022 Posted December 6, 2022 Those are PGSSUB subtitles that are graphical, i.e. based on images. Subkiller only extracts text based subtitles that would show up in Emby as SUBRIP. They will be extracted to a .SRT file which can be read with Notepad or any other text editor. 2
Medic97 4 Posted December 6, 2022 Posted December 6, 2022 (edited) 3 minutes ago, Dickydodah! said: Those are PGSSUB subtitles that are graphical, i.e. based on images. Subkiller only extracts text based subtitles that would show up in Emby as SUBRIP. They will be extracted to a .SRT file which can be read with Notepad or any other text editor. Awesome thanks for the help. I am new to Emby and all this customization. What about Codec: MOV_TEXT is that considered a text based? Edited December 6, 2022 by Medic97
Dickydodah! 154 Posted December 6, 2022 Posted December 6, 2022 I believe MOV_TEXT are text based but in Quicktime .mov files. I don't know if SubKiller will deal with these as I've never seen one.
Medic97 4 Posted December 6, 2022 Posted December 6, 2022 Just now, Dickydodah! said: I believe MOV_TEXT are text based but in Quicktime .mov files. I don't know if SubKiller will deal with these as I've never seen one. yeah it's an mp4. I guess it doesn't matter much. Though it would be nice to remove them but it's not like there in the way or anything.
Dickydodah! 154 Posted December 6, 2022 Posted December 6, 2022 The main use for myself is to reduce the number of embedded subs as Samsung TV's don't play nice with lot's of subs. I'm not sure of the maximum before issues are seen but 3 or 4 definitely don't cause an issue but 30 plus do. 1
Cheesegeezer 3106 Posted December 6, 2022 Author Posted December 6, 2022 49 minutes ago, Dickydodah! said: I believe MOV_TEXT are text based but in Quicktime .mov files. I don't know if SubKiller will deal with these as I've never seen one. hmmm yeah me neither. but it uses ffmpeg to process so i don't think that would be an issue. i'll have a check tomorrow.
gihayes 47 Posted December 7, 2022 Posted December 7, 2022 Getting errors similar to those posted above. Can you help? embyserver (1).txt
Cheesegeezer 3106 Posted December 8, 2022 Author Posted December 8, 2022 1 hour ago, gihayes said: Getting errors similar to those posted above. Can you help? embyserver (1).txt 101.64 kB · 1 download I tink i need to update all my plugin nugets to 4.7.9 ill do it in the morning fella
gihayes 47 Posted December 8, 2022 Posted December 8, 2022 20 minutes ago, Cheesegeezer said: I tink i need to update all my plugin nugets to 4.7.9 ill do it in the morning fella Thanks
Stellarat 12 Posted December 8, 2022 Posted December 8, 2022 (edited) Hi, Excited to try this out, but unfortunately nothing is processed and I'm getting:, 2022-12-08 18:58:23.238 Info Server: http/1.1 POST http://192.168.0.2:8096/emby/ScheduledTasks/Running/a68cbabd002d557c1e1c21c43d74fef7?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=49d6d4b7-74b5-49d0-80ce-fc9ff37c187c&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 18:58:23.241 Info Server: http/1.1 Response 204 to host1. Time: 3ms. http://192.168.0.2:8096/emby/ScheduledTasks/Running/a68cbabd002d557c1e1c21c43d74fef7?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=49d6d4b7-74b5-49d0-80ce-fc9ff37c187c&X-Emby-Client-Version=4.7.10.0 2022-12-08 18:58:23.530 Error TaskManager: Error *** Error Report *** Version: 4.7.10.0 Command line: C:\Users\Jason\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.10 OS/Process: x64/x64 Runtime: C:/Users/Jason/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\Jason\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Jason\AppData\Roaming\Emby-Server\system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.SubKiller.ScheduledTasks.SubKillerScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: Emby.SubKiller TargetSite: Void MoveNext() Edited December 8, 2022 by Stellarat
Cheesegeezer 3106 Posted December 8, 2022 Author Posted December 8, 2022 Yep I’m just getting home from work and will do the compatibility updates. Should see a release in an hour or so 1 1
Cheesegeezer 3106 Posted December 9, 2022 Author Posted December 9, 2022 I updated the plugin hours ago, generally silence is a good sign i updated the rest of my plugins too 1
gihayes 47 Posted December 9, 2022 Posted December 9, 2022 8 hours ago, Cheesegeezer said: I updated the plugin hours ago, generally silence is a good sign i updated the rest of my plugins too Just started a run. So far, so good. 1 1
Dickydodah! 154 Posted December 9, 2022 Posted December 9, 2022 (edited) Hi @Cheesegeezer I've tested on a file with loads of subs including English, English (Forced) and English (SDH). It recognised all three English Subs but only extracted two. Is the SDH extraction in this build? It also threw an error but I can't see exactly why. embyserver.txt I think the SDH subs are being overwritten with the full English subs so I'm guessing SDH isn't yet implemented Edited December 9, 2022 by Dickydodah!
