Przemek 70 Posted September 23, 2022 Posted September 23, 2022 Hello, today my Canal +Box logout my Emby. When I try to connect I have information that I have to go to browser to website emby.media/pin and put there Pin: `PIN` It's something wrong with Your Emby Connect service or my Android Box? Regards, Przemek
Solution ebr 16337 Posted September 24, 2022 Solution Posted September 24, 2022 Hi. It sounds like maybe your device has lost connectivity. Can you confirm that? Can you log into your server manually with the IP address?
Przemek 70 Posted September 24, 2022 Author Posted September 24, 2022 Hi, it's strange situation. My plc adapter disconnect ethernet from network and my Android box have automatically connect to wifi. I try Amazon Prime Video and that works sometimes and sometimes not. YouTube works. Emby not. I see on settings of that Canal+box that is connected to my old wifi. I don't know how it's possible because that old wifi is disabled and it is from old router that is in bridge mode. I connect in box to new wifi and everything works. I can connect with Pin. Now I pair plc again. Thanks and regards.
Przemek 70 Posted September 27, 2022 Author Posted September 27, 2022 2 minutes ago, Luke said: Are you all set now? Yes, thanks that was that strange situation with connection. Now I have ethernet with PLC connected and works perfect. Regards. 1
