ProNetGuru 4 Posted September 23, 2022 Posted September 23, 2022 I've installed this plugin last night and while I can confirm it is doing what it's supposed to (combining movies across different libraries) I'm seeing an extreme performance hit. I'm running Emby 4.7.6 on a Synology DS1621xs+, and Emby rarely uses more than 3-4GB RAM. I installed the plugin at ~10pm last night, and by mid-day today, the Emby process had consumed ~22GB of RAM but it was still responsive. Unfortunately, I couldn't look into it further due to work, but by 8pmtonight, Emby was totally unresponsive. None of my clients (Android TV, Shield, FireTV, Android Mobile) could connect, and the web interface timed out. I couldn't stop the service via Package Manager or API, and ended up needing to reboot my Synology to get it functioning normally again. I suspect my issue is due to a ridiculous amount of content being scanned across multiple libraries. Is there a way to exclude certain libraries that I don't want combined from being scanned/collected to test this theory? Here are some snippets from my log: 2022-09-22 20:26:57.454 Error LibraryMonitor: Error watching path: /volume1/Movies *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() 2022-09-22 20:26:57.458 Error LibraryMonitor: Error watching path: /volume1/Emby/DVR *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() 2022-09-22 20:26:57.551 Error LibraryMonitor: Error watching path: /volume1/VOD/Movies *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() 2022-09-22 20:26:58.173 Error LibraryMonitor: Error watching path: /volume1/Movies4K *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() 2022-09-22 20:26:58.173 Error LibraryMonitor: Error watching path: /volume1/VOD/Series *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents()
Luke 42243 Posted September 23, 2022 Posted September 23, 2022 3 minutes ago, ProNetGuru said: I've installed this plugin last night and while I can confirm it is doing what it's supposed to (combining movies across different libraries) I'm seeing an extreme performance hit. I'm running Emby 4.7.6 on a Synology DS1621xs+, and Emby rarely uses more than 3-4GB RAM. I installed the plugin at ~10pm last night, and by mid-day today, the Emby process had consumed ~22GB of RAM but it was still responsive. Unfortunately, I couldn't look into it further due to work, but by 8pmtonight, Emby was totally unresponsive. None of my clients (Android TV, Shield, FireTV, Android Mobile) could connect, and the web interface timed out. I couldn't stop the service via Package Manager or API, and ended up needing to reboot my Synology to get it functioning normally again. I suspect my issue is due to a ridiculous amount of content being scanned across multiple libraries. Is there a way to exclude certain libraries that I don't want combined from being scanned/collected to test this theory? Here are some snippets from my log: 2022-09-22 20:26:57.454 Error LibraryMonitor: Error watching path: /volume1/Movies *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() 2022-09-22 20:26:57.458 Error LibraryMonitor: Error watching path: /volume1/Emby/DVR *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() 2022-09-22 20:26:57.551 Error LibraryMonitor: Error watching path: /volume1/VOD/Movies *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() 2022-09-22 20:26:58.173 Error LibraryMonitor: Error watching path: /volume1/Movies4K *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() 2022-09-22 20:26:58.173 Error LibraryMonitor: Error watching path: /volume1/VOD/Series *** Error Report *** Version: 4.7.6.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42661 SMP Mon Jun 27 15:07:23 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached. at System.IO.FileSystemWatcher.StartRaisingEvents() at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem.Watcher TargetSite: Void StartRaisingEvents() Hi there, please attach the complete server log file. Thanks.
Solution Happy2Play 9811 Posted September 23, 2022 Solution Posted September 23, 2022 (edited) @ProNetGuruSplit to own topic as this error have nothing to do with plugins as you need to change inotify on the platform. But if there is further issues, we can change the title and provide server log for further investigation. Edited September 23, 2022 by Happy2Play 1
ProNetGuru 4 Posted September 23, 2022 Author Posted September 23, 2022 I implemented the RTM fix on my Synology, so that will hopefully resolve 1 issue. That still doesn't explain why my memory utilization skyrocketed as I've been running Emby on the same equipment for nearly a year without issue. The only thing that changed in my configuration was the addition of the AutoCollection.dll plugin. That said, I'm going to be traveling for the next 2 weeks, so I've temporarily removed the plugin since I don't want to incur family wrath if I can't remotely reset/fix Emby. I'll try testing the plugin again in a few weeks when I return and post a reply if I continue to experience the same symptoms. Thanks!
Luke 42243 Posted September 23, 2022 Posted September 23, 2022 10 hours ago, Luke said: Hi there, please attach the complete server log file. Thanks. @ProNetGuru
ProNetGuru 4 Posted November 28, 2022 Author Posted November 28, 2022 Performing the RTM fix seemed to resolve the runaway memory usage on the embyserver process. Everything appears to be working normally for the last several weeks. Thank you! 1 1
