dgrigo 35 Posted September 22, 2022 Posted September 22, 2022 (edited) UPDATE 12/1 After Emby app going to 4.7.11.0 and truenas scale to Bluefin, all is fixed with ought my modification, host networking works with 8096 8920 ports, and the official chart install have all options working and install is easier than ever. All options working just know the requirement to use cast on chrome has changed to SSL, no ssl, no cast. That's why using http the menu to cast is empty. My suggestion is if you want to expose on web, your server, to use nginx reverse proxy and ssl with certbot in a raspberry PI. That way you select in networking setup handled by reverse proxy and you forget about certificate updates, it is handled by certbot and lets encrypt. you can see port 1900 is exposed! Ok, host networking is not working by default if you don't do some editing on 2 files first deployment.yaml in /mnt/your Storage/ix-applications/releases/emby/charts/1.0.11/templates replace all 8096 to 9096 and save! then on emby wherever you setup the config to be /config/system.xml replace 8096 to 9096 and save, (btw i had replaced also the https to be above the 9000 requirement in scale. stop emby, and do a redeploy with host network checked. Voila , hope i helped you! Just make sure no other app asks for the same ports, that's the only limitation of using host networking and for this to work you had to have installed emby first with ought clicking the host networking @ first install, so the files are generated. regards Dinos Edited January 12, 2023 by dgrigo picture 1
larryjay 1 Posted September 26, 2022 Posted September 26, 2022 Dinos, Thanks for your insight into the mystery of ixSystems Charts and such other fun. Greatly appreciate your help Larry
dgrigo 35 Posted September 27, 2022 Author Posted September 27, 2022 Thank you guys, btw if anyone needs https the easy way again with official charts , I have solved it too, just ask and will post what you must do. You off course need to have ssl ready at your server. 1
dgrigo 35 Posted October 3, 2022 Author Posted October 3, 2022 For upgrade, to latest version do install it will generate error, just ignore, stop service, edit deployment.yaml in /mnt/your Storage/ix-applications/releases/emby/charts/1.0.12/templates replace all 8096 to 9096 and save! then start , if not working unmark host networking apply, remark host networking , apply.
Luke 42245 Posted October 3, 2022 Posted October 3, 2022 HI, are you saying truenas scale doesn't allow any ports under 9000?
dgrigo 35 Posted October 3, 2022 Author Posted October 3, 2022 (edited) @Luke kubernetes limitation That's why I asked if we can go 9000+ as default. You know instead of going port 8096:9096 And as we can't specify 8920 to a higher port, and if ports don't match we can't enable host networking, no host networking no dlna or wake on lan too. By using modification on the emby and docker deployment, I solved all the limitations , even the https working on port 9920. Thanks Edited October 17, 2022 by dgrigo More info
YoloSan 0 Posted December 8, 2022 Posted December 8, 2022 Hi. @dgrigo I'm on 1.0.15 and did all the changes you've mentioned - changed the ports in the two files, ticked `Enable Host Network` - stopped the container and started it again, but it's not starting anymore. It's stuck on Deploying. I've unticked and reticked `Enable Host Network`, same thing.
dgrigo 35 Posted December 8, 2022 Author Posted December 8, 2022 (edited) They changed some files, i will post the changes for you. Deployment.yaml change 8096 to 9096 Portal.tpl change 8096 to 9096 service-tcp.yaml all 8096 to 9096 and off course make sure you emby system config points to 9096 and 9920. that should allow you to start it, first with ought the host networking , and then modify and open Host again the files are in the same directory. PS for anyone running on Bluefin like I do, stop samba shares and reactivate them after the container opens, or go to apps kubernates settings : advanced and untick the Validate host path @YoloSan Edited December 8, 2022 by dgrigo 1
sfatula 208 Posted December 8, 2022 Posted December 8, 2022 On 10/3/2022 at 3:08 PM, Luke said: HI, are you saying truenas scale doesn't allow any ports under 9000? When you use Truenas application catalog (from IX systems), it does not allow below port 9000. If you use a third party catalog such as truecharts, it does allow < 9000. That's the only reason I am using the truecharts Emby chart instead of the IX systems chart.
dgrigo 35 Posted December 8, 2022 Author Posted December 8, 2022 That's exactly what I solved, I run pihole,qbittorrent and emby SSL all through official catalogue, I disliked truecharts.
