SGBVida 1 Posted September 21, 2022 Posted September 21, 2022 Hello, I try to setup the live TV with emby (I have the emby premiere subscription) without success I just had the following url in the TV source: http://mafreebox.freebox.fr/freeboxtv/playlist.m3u This in a quick extract of the file: #EXTM3U #EXTINF:0,2 - France 2 (bas débit) rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=201&flavour=ld #EXTINF:0,2 - France 2 (HD) rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=201&flavour=hd #EXTINF:0,2 - France 2 (standard) rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=201&flavour=sd #EXTINF:0,2 - France 2 (auto) rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=201 #EXTINF:0,3 - France 3 (standard) rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=202&flavour=sd #EXTINF:0,3 - France 3 (bas débit) rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=202&flavour=ld #EXTINF:0,3 - France 3 (HD) rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=202&flavour=hd Unfortunaly after few seconde I have an error : No compatible streams are currently available. Please try again later or contact your system administrator for details. I add in attachement some logs. Best Regards, David ffmpeg-transcode-636b76cc-635d-4346-8a28-1bb9a714c6b5_1.txt ffmpeg-transcode-958d5c34-dfd0-42b5-bb40-0bad27c15e21_1.txt embyserver.txt
Luke 42242 Posted September 23, 2022 Posted September 23, 2022 @SGBVida your provider is returning 404 not found errors. I would try refreshing the guide data in emby server and see if that helps, just in case it had already fallen out of date with your provider. Please let us know if this helps. Thanks.
SGBVida 1 Posted September 24, 2022 Author Posted September 24, 2022 Hello, thanks for the reply, well seems it's not working. What do you mean by "already fallen out of date with your provider." ?
Luke 42242 Posted September 25, 2022 Posted September 25, 2022 8 hours ago, SGBVida said: Hello, thanks for the reply, well seems it's not working. What do you mean by "already fallen out of date with your provider." ? By default Emby Server updates the guide data every 24 hours, but for example if your provider is changing the m3u contents every 12 hours, then you'd need to adjust the schedule in Emby Server. So you did try refreshing the guide data?
SGBVida 1 Posted September 28, 2022 Author Posted September 28, 2022 I didn't install guide data, I would try before live TV than add guide data! is it mandatory ?
Luke 42242 Posted September 28, 2022 Posted September 28, 2022 2 hours ago, SGBVida said: I didn't install guide data, I would try before live TV than add guide data! is it mandatory ? Sorry what I mean is maybe your provider changes the contents of the m3u periodically. Does the contents of that m3u ever change?
SGBVida 1 Posted October 3, 2022 Author Posted October 3, 2022 I checked seems not, urls are always same
SGBVida 1 Posted October 3, 2022 Author Posted October 3, 2022 I just try and it works. the url is shared by the isp box so only if you are in "free" you can see the content.
SGBVida 1 Posted October 3, 2022 Author Posted October 3, 2022 (edited) Maybe it could help you if I explain my infra: I have a router (ISP) I use a Kubernetes cluster where Emby is hosted with traefik as reverse proxy. I created an ingress route to forward all traffic from https where the hostname match with Emby.mydomain.fr to Emby pod I try to read the M3U hosted on the ISP box, it work with VLC but with Emby Edited October 3, 2022 by SGBVida
EODCrafter 181 Posted October 4, 2022 Posted October 4, 2022 Sounds like you know what your doing! GL.
