Mousey369 6 Posted September 19, 2022 Posted September 19, 2022 Hello, Today my Sony Bravia received a software update and since then I cannot log into my emby server form android TV app. The android app on my phone seems to work fine. Upon startup, the emby app gives a volley error, and my previously saved credentials are no longer there. I enter them manually, and on the server dashboard i can see authentication was successful, but the TV app does not load. I have already done a reinstall of the app and that changed nothing. Any idea what could cause this?
ebr 16337 Posted September 19, 2022 Posted September 19, 2022 1 hour ago, Mousey369 said: app gives a volley error, Exactly what does the message say? On the manual login screen, is there a "Send Logs" button?
Mousey369 6 Posted September 19, 2022 Author Posted September 19, 2022 Yes there is a send logs button. I will do that now.
ebr 16337 Posted September 19, 2022 Posted September 19, 2022 3 hours ago, Mousey369 said: I will do that now. Please cause the error first and then, when you do, please tell me exactly what time you pressed the button. Thanks.
Mousey369 6 Posted September 20, 2022 Author Posted September 20, 2022 14 hours ago, ebr said: Please cause the error first and then, when you do, please tell me exactly what time you pressed the button. Thanks. I did it at the exact moment I posted that.
Mousey369 6 Posted September 20, 2022 Author Posted September 20, 2022 Update: It worked normally this morning and logged me in. Then I closed the app and opened it again and the behavior happened again. At this moment I have sent a log.
ebr 16337 Posted September 20, 2022 Posted September 20, 2022 The attempt to reach your server is timing out. Is your server IP address 192.168.1.10:8096?
Mousey369 6 Posted September 20, 2022 Author Posted September 20, 2022 1 hour ago, ebr said: The attempt to reach your server is timing out. Is your server IP address 192.168.1.10:8096? Yes it is. And there is nothing wrong with the TV's network connection as I can use my other streaming apps with no issue. Additionally, my android phone can also connect to the server without issue.
ebr 16337 Posted September 21, 2022 Posted September 21, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Mousey369 6 Posted September 22, 2022 Author Posted September 22, 2022 (edited) Update: It has started randomly working. Not sure what changed as I didn't make any changes. But solved for now Edited September 22, 2022 by Mousey369 1
