gsites 14 Posted September 19, 2022 Posted September 19, 2022 urn up the volume, make the volume louder I use MiBox TVs The volume of other apps is very loud, netflix, amazon, disney, etc... But, in emby the volume is very low, I need to leave it on maximum to hear a little. How to increase the total overall volume of the emby, where to make this adjustment? thanks
Luke 42243 Posted September 19, 2022 Posted September 19, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
chrysler300 4 Posted September 22, 2022 Posted September 22, 2022 Hi! Seems like this "problem"has been ongoing. I have the same problem.I have used Kodi before and Kodi has an "Volumebooster"..increaser in the setting..and it works very well. It make the speech louder. The speech turn very clear and loud when using it. is it possible to make this happen in Emby?I used Kodi before and turned to Emby cause it was "faster"and I could stop a movie and watch it on another place. But now,somwtimes I´m back to Kodi..cause the "volume"is to low..cant hear the speech. Have Emby done anything about this?anything I can try?It seems like many have this issue! I do not transcode..just playing movies "as they are". Can I do something to adjust the volume?anything at all?
Luke 42243 Posted September 23, 2022 Posted September 23, 2022 On 9/22/2022 at 3:32 AM, chrysler300 said: Hi! Seems like this "problem"has been ongoing. I have the same problem.I have used Kodi before and Kodi has an "Volumebooster"..increaser in the setting..and it works very well. It make the speech louder. The speech turn very clear and loud when using it. is it possible to make this happen in Emby?I used Kodi before and turned to Emby cause it was "faster"and I could stop a movie and watch it on another place. But now,somwtimes I´m back to Kodi..cause the "volume"is to low..cant hear the speech. Have Emby done anything about this?anything I can try?It seems like many have this issue! I do not transcode..just playing movies "as they are". Can I do something to adjust the volume?anything at all? @chrysler300 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
chrysler300 4 Posted September 23, 2022 Posted September 23, 2022 Hi! Same issue! Any ideas? Solution? Have Emby done anything about this?
Luke 42243 Posted September 23, 2022 Posted September 23, 2022 18 minutes ago, chrysler300 said: Hi! Same issue! Any ideas? Solution? Have Emby done anything about this? Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Luke 42243 Posted September 23, 2022 Posted September 23, 2022 18 minutes ago, chrysler300 said: Hi again! No,thanks! Hi, we're happy to help. We're just looking for a little more information that can help us help you. Thanks.
chrysler300 4 Posted September 26, 2022 Posted September 26, 2022 Its the same problem that many have had over a period of year!"low volume" Have not acually seen any solution,so far...!And no "settings"in Emby that could help. Its easier to go back to a "player"that dont have this "issue" But thanks for replying!
bandit8623 226 Posted September 27, 2022 Posted September 27, 2022 (edited) 17 hours ago, chrysler300 said: Its the same problem that many have had over a period of year!"low volume" Have not acually seen any solution,so far...!And no "settings"in Emby that could help. Its easier to go back to a "player"that dont have this "issue" But thanks for replying! is your audio being down converted? if there is downmixing have you played with this setting? this setting is a server setting under transcoding. Edited September 27, 2022 by bandit8623
ebr 16337 Posted September 27, 2022 Posted September 27, 2022 Hi. We have not discovered why some people have an issue with this when others don't. None of my test systems have this problem when downmixing. The volume is on par with other apps on the device.
chrysler300 4 Posted September 27, 2022 Posted September 27, 2022 Ok,just happy that there are alternatives! Problems on my old system,and the new one! But any other player sound fine and also streamingapp and any other app too!...Kodi,VLC...e.t.c I will leave this at this point!
Mookdog 90 Posted November 13, 2022 Posted November 13, 2022 I have the same problem on Emby for ATV and Regular Android App. Very low volume. Even my uncle complains of low volume on his pc using Emby Theater Its across the board just low. Tried it on a formuler gtv and a Shield TV both the same Volume low Mook
chrysler300 4 Posted November 13, 2022 Posted November 13, 2022 (edited) We.. I sold my pretty large soundsystem ,Emby was good on that but I wanted some smaller system.So I bought Audio Pro speakers,..not good. So I returned them and bought a Soundbar,and kept two subwoofers...so that solved the problem! But again..Kodi,VLC they both sounded good...on all my systems.(Kodi has a spec. setting to adjust and VLC has an EQ that does it better,but I use Emby now,with the soundbar and woofers) Edited November 13, 2022 by chrysler300
chrysler300 4 Posted December 4, 2022 Posted December 4, 2022 And now I bought a new TV,and it made it even better...but still, nothing beats KODI...regarding the speechvolume. But it´s Ok!It`s manageable!
SoniC_1 0 Posted January 16, 2023 Posted January 16, 2023 Why won't you simply include a "volume boost" not only during transcoding but in general ? And make this optional with a warning that this could seriously impact the quality or even damage your sound system ? Similar to VLC and whatnots.... I am a premium member because I like Emby, but seriously..... this has been requested over and over and over again.... Just... include it into your clients.... Believe me - People WILL be happy. Thanks. P.S. I am also seeing a low volume in some movies.... Of course I could turn the volume up on my soundsystem, but it is adjusted to be "ok" for everything else than Emby, so why should I touch it. BOOST OPTION PLZ!
Luke 42243 Posted January 17, 2023 Posted January 17, 2023 23 hours ago, SoniC_1 said: Why won't you simply include a "volume boost" not only during transcoding but in general ? And make this optional with a warning that this could seriously impact the quality or even damage your sound system ? Similar to VLC and whatnots.... I am a premium member because I like Emby, but seriously..... this has been requested over and over and over again.... Just... include it into your clients.... Believe me - People WILL be happy. Thanks. P.S. I am also seeing a low volume in some movies.... Of course I could turn the volume up on my soundsystem, but it is adjusted to be "ok" for everything else than Emby, so why should I touch it. BOOST OPTION PLZ! Re:
Kilroy5150 1 Posted July 14, 2024 Posted July 14, 2024 It seems like the system's built in codexs are probably translating the sound wrong on certain TVs. I've got a soundbar at %75 and the tv volume at %50 and can "barely" hear it with my a/c running, yet i can go to Youtube and it's BLASTING at those volumes. Obviously the problem is IN the software and how it's translating the movie's sounds output through the emby player but people seem to want to work "around" the issue rather than just fixing the software by putting a volume adjustment implement into the system. VolumeBoost works great on some systems while totally ineffective on others. 1
Luke 42243 Posted July 16, 2024 Posted July 16, 2024 On 7/14/2024 at 5:29 PM, victor@vialy.com said: Where is the "volumeboost"? Located? Hi, it is in server transcoding settings, however it is used in a specific situation - transcoding with downmixing.
victor@vialy.com 9 Posted July 17, 2024 Posted July 17, 2024 10 hours ago, Luke said: Hi, it is in server transcoding settings, however it is used in a specific situation - transcoding with downmixing. Oh... Not good. Any plans to add this function for every format with no down mixing?
ebr 16337 Posted July 17, 2024 Posted July 17, 2024 4 hours ago, victor@vialy.com said: Any plans to add this function for every format with no down mixing? Hi. A compressed bitstream (like DD, DD+ DTS, etc.) cannot be adjusted for volume.
victor@vialy.com 9 Posted July 17, 2024 Posted July 17, 2024 Then... Could be there a workaround directly from the app to boost it?
Luke 42243 Posted July 20, 2024 Posted July 20, 2024 On 7/17/2024 at 9:55 AM, victor@vialy.com said: Then... Could be there a workaround directly from the app to boost it? @victor@vialy.comcan we please look at an example of what you're playing as well as what your audio setup looks like? How to Report a Problem Thanks !
