troyhough 61 Posted November 21, 2022 Posted November 21, 2022 2 minutes ago, roaku said: Are you playing back MPEG2 video in any other app? Channels DVR and VLC. 1
Press1Now 3 Posted November 22, 2022 Posted November 22, 2022 Just curious, Any updates on this ? I just bought the Pixel 7 Pro and getting the same thing. Only happens on Live TV and recorded Live TV. 1
Luke 42241 Posted November 30, 2022 Posted November 30, 2022 On 11/22/2022 at 6:39 PM, Press1Now said: Just curious, Any updates on this ? I just bought the Pixel 7 Pro and getting the same thing. Only happens on Live TV and recorded Live TV. HI, we are looking into it. Thanks. 1
Fred25 1 Posted December 3, 2022 Posted December 3, 2022 I have Pixel 7. I have this same issue when doing live TV that are not HD and playing back recording that are not HD HD channels play fine. Also if I am playing a non HD file if I change the Quality from Auto to 480P-kpbs the display is OK. 1
swhiting 3 Posted December 4, 2022 Posted December 4, 2022 I have a similar issue with my Pixel 7 Pro (Android 13). Every time I play a video through the app (it doesn't matter if it's Live TV or not), I get the weird discolored look. The only solutions I have found so far are either setting the In-App settings for video playback to a lower quality which fixes the color issue but increases buffering since it now needs to be transcoded further, or accessing the videos via a web browser. Please fix this. 2
miniz98 73 Posted December 17, 2022 Posted December 17, 2022 Do you know when this will be fixed. I can't watch on my pixel 7. Thanks. 1
StretchF 0 Posted January 15, 2023 Posted January 15, 2023 (edited) Thank you to swhiting for the workaround. I have been aware of this issue for many months with my Pixel 6 (Android 13). The discoloration only happens for Live TV SD channels. HD channels are fine. Using the HDHomerun app all SD and HD channels play correctly. The problem does not happen when using EMBY on Windows or iOS In the Emby Android app, Click on the Login icon and select App Settings (Emby for Android 3.2.90) Select Playback and under Video, change Home network quality to 720p - 2 Mbps (720p - 3 and 4 Mbps did not correct the problem) I also changed the setting for Internet quality to 720p - 2 Mbps Edited January 15, 2023 by StretchF
troyhough 61 Posted January 21, 2023 Posted January 21, 2023 (edited) Just got 3.2.92 on my P7P. Live TV discolor issue appears to be fixed! Edited January 21, 2023 by troyhough 1
RogerK 9 Posted January 21, 2023 Posted January 21, 2023 I also have 3.2.92 and my Pixel 7 is still discolored.
Luke 42241 Posted January 21, 2023 Posted January 21, 2023 17 minutes ago, troyhough said: Just got 3.2.92 on my P7P. Live TV discolor issue appears to be fixed! Are you positive? Can you double check that it was direct playing? 1
troyhough 61 Posted January 21, 2023 Posted January 21, 2023 9 minutes ago, Luke said: Are you positive? Can you double check that it was direct playing? Crap you're right. Was testing a 4K feed last night w/ transcoding and forgot to set it back to max.
MikeD315 5 Posted April 7, 2023 Posted April 7, 2023 So, is this just never going to work on Pixel phones? What's the deal here? Is it the phone or Emby? 1 1
troyhough 61 Posted April 13, 2023 Posted April 13, 2023 On 4/6/2023 at 9:05 PM, MikeD315 said: So, is this just never going to work on Pixel phones? What's the deal here? Is it the phone or Emby? It's not the phone. Playback is perfect with VLC and Channels DVR. 1
VuongNguyen 2 Posted May 11, 2023 Posted May 11, 2023 Hi! I just received my monthly receipt for emby and was reminded of this issue. Is this a Pixel specific issue? Is there an ETA for a fix? 1
Chiefmas 40 Posted May 17, 2023 Posted May 17, 2023 (edited) putting a tldr in, but honestly, the tldr section is still long itself. Chiming in here- my post will be a slight hijack, but it seems like it might be related. I'm seeing the same issues on a Pixel 6 Pro with various old media formats. I've been doing some testing, it's not totally thorough though, and apologies, I didn't organize the codec observations well. I've seen it happening in: WMV2 WMV3 MPEG-2 MPEG-4 with Advanced Simple Profile@L5 sorta MPEG-1 There are some interesting things that I've noticed, that are at least part of the problem in my case, but maybe will help you guys figure the problem out. With the mpeg-1 streams, I've noticed that they are program streams. The video wasn't displaying, but the audio does, with glitches. I then tried remuxing the file to mp4. This gives me a somewhat similar result, but not exact. The remuxed file wouldn't play at all, no audio or video. I then accidentally locked my screen, and found it would play from the lock screen, and no longer had the glitches. The remux seemed to fix audio, which I am guessing is it having trouble with the original file being a mpeg program stream; it can demux mp4 properly so it handle the audio fine, but I don't think the modern phones have hw support for the old mpeg-1 format(which I think this particular video is in). So it seems like the video stream, if the hardware can't cope with it at all, jams things up. when the screen was locked, I think it's just discarding the video stream, and it could handle the mp3 audio, so it would play. This was indicated as using Direct Play. With the WMV streams, it was somewhat not surprising, my server shows Direct Streaming, and I'm not sure how well the WMV streams are supported; that said- I then tried using BSPlayer to play the files back(VLC is great, but it doesn't tell you when it's fallen back to software decode). BSP indicates for WMV, it drops back to software playback, no surprise there. I have some AVI files that have video encoded with a few different codecs(Xvid vs DivX) and different settings (2 are ASP@L5, one is Simple@L3). With the ASP@L5 files, things start to get wonky. One was encoded with Xvid, it gets direct streamed and works fine, the other is DivX, and does the pause/no video, but plays audio when paused like the mpeg-1 video. Besides the encoder, the other obvious difference, the one that doesn't play properly is BVOP1, the one that does is BVOP2. I don't know if that's the source of the issue, but it was the most obvious difference- comparing metadata between Xvid and DivX is rather a pain- that's what stood out. BSPlayer tries a hw decode pipeline with both of these, but as with Emby, only the one plays. Now, I had one AVI that had a Simple@L3 encoded with Xvid. In this case, all seemed fine, and then I realized Emby had actually decided to transcode this one- it's surprising it transcodes this one but not the other mpeg-4 encodes. BSPlayer also dropped back to software decode, so the hw seems to indicate that it can't do Simple Profile at all? Seems weird that it can do some ASP, or at least tries to, but whatever.... The mpeg-2 video I tested get direct streamed, and has the color shift. BSPlayer indicates that it is dropping back to software decode for both mpeg-1 and mpeg-2. In both cases it also indicates that after the decode stage, it's using a GPU assisted conversion to RGB32 (Unsurprisingly, they are stored in YUV color spaces). Everything plays fine when using pure software decode on BSPlayer(and VLC android, which I also did some tests with), and from a PC. I don't think any of the files have any stream or file corruption. I did some light searching, and came across this: https://developer.android.com/guide/topics/media/media-formats TLDR; So, putting all of that together, for the Live TV issues, I wonder if maybe they are getting an mpeg-2 stream in the broadcast and it's not coping with that correctly, or maybe the GPU RGB conversion is happening or not happening when it should/shouldn't after a decode stage? I could see the color shift being a result of the color space not being translated to RGB32 when it should. That link doesn't explicitly mention mpeg-2 within a MPEG TS, but I could also see maybe they didn't bother, since you don't see mpeg-2 transport streams as much any more. Of course, that could vary by whatever the local broadcaster is doing I suppose. For my particular issues, it seems like the Android client should request transcoding for mpeg-4 part 2 streams, WMV, and anything else that's not AVC/HEVC. I seem to be getting direct streams for those codecs, and it seems like for max compatibility, it's probably safest to just assume you can't direct stream those codecs, probably even mpeg-2 if I'm being honest, though that probably doesn't happen as much. You could see it in some BluRay rips, though I don't think you see mpeg-2 on BluRay much anymore these days. Hopefully that might help you guys track down the issues...maybe other folks having Live TV color shifts can check their feeds to see what color space and codec is being used in the broadcast, that might prove helpful I think... Addendum: I just scrolled the link a little bit more and see in the video codecs they do say the explicitly support MPEG-4 SP, but it expects it to be in a 3gp container. I wonder if I remux to 3gp if that would make it work, but I don't run into it that often and so I don't care enough to mess with it any further. They don't mention ASP at all, which I think just supports my earlier suggestion that if mpeg-4 pt2 (or nearly anything else that's not H264/h265 already) content is seen, the best option, at least for Android players is to just transcode those without bothering with a DirectPlay/DirectStream. I suppose VP8 and VP9 could be left alone, but honestly, those are so rare IME, I don't really care much about them, I'd rather more focus be on AV1 than the older iterations. Incidentally, I did try playing through the web browser instead- unsurprisingly everything plays back fine there, but the browser profile for Emby is just causing all of them to get transcoded to h264. Edited May 17, 2023 by Chiefmas
MikeD315 5 Posted May 18, 2023 Posted May 18, 2023 (edited) So, this issue doesn't happen with the latest version of Jellyfin, however I noticed that Jellyfin by default is transcoding everything. Streaming a regular ATSC 1.0 channel I see the following in the Jellyfin dashboard for my Pixel 7 running their Android client: The media is being converted into a format that is compatible with the device that is playing the media. Framerate: 32fps 20.4 Mbps TS H264 AAC Reason for transcoding: The container is not supported The video codec is not supported The audio codec is not supported In contrast, when I check the Emby dashboard while playing it shows direct play for everything, stream, video and audio are all direct play. Edited May 18, 2023 by MikeD315
Luke 42241 Posted May 18, 2023 Posted May 18, 2023 Is anyone on the android 14 beta? One user has reported this resolved with that.
miniz98 73 Posted May 19, 2023 Posted May 19, 2023 Yes I can confirm android beta fixes the color issue.
troyhough 61 Posted May 24, 2023 Posted May 24, 2023 On 5/18/2023 at 10:46 AM, Luke said: Is anyone on the android 14 beta? One user has reported this resolved with that. So we should be good to go in November?
ctn06675 2 Posted July 19, 2023 Posted July 19, 2023 Same issue on a Pixel 6 on Android 13 running latest production build 1
Solution BMelz 2 Posted October 13, 2023 Solution Posted October 13, 2023 (edited) Confirmed resolved in latest Android 14 release. Edited October 13, 2023 by BMelz 1 1
troyhough 61 Posted October 19, 2023 Posted October 19, 2023 On 10/13/2023 at 5:29 PM, BMelz said: Confirmed resolved in latest Android 14 release. Yes fixed on pixel 8 running Android 14. 1 1
