roaku 842 Posted September 19, 2022 Posted September 19, 2022 6 minutes ago, mickle026 said: I might have missed the meaning of this in your earlier explanation, trying it now function (loading) { return function (page) { var pluginUniqueId = "B19C4634-2C02-4DD9-8579-F950961EB219"; page.addEventListener('viewshow', () => { ApiClient.getJSON(ApiClient.getUrl('CPP/MainHeader.html/LoadHTML')).then(response => { var dat = response; page.getElementById("header").innerHTML = dat.Text; console.log(dat.Text); }).catch(e => { console.log(e); }); } ); } } page.getElementById("header").innerHTML = dat.Text; - doesn't update anything, its like the element header cannot be found within the page array document.getElementById("header").innerHTML = dat.Text; - document updates the label 1 in 3 times view doesn't exist This is still lost on me - lol ! I'll get there though the more i do the more will sink into this brainy thing of mine.... Try: function (loading) { return function (page) { var pluginUniqueId = "B19C4634-2C02-4DD9-8579-F950961EB219"; //Assign outside of eventlistener scope let headerElement = page.getElementById("header"); page.addEventListener('viewshow', () => { ApiClient.getJSON(ApiClient.getUrl('CPP/MainHeader.html/LoadHTML')).then(response => { var dat = response; headerElement.innerHTML = dat.Text; console.log(dat.Text); }).catch(e => { console.log(e); }); } ); } } 1
roaku 842 Posted September 19, 2022 Posted September 19, 2022 @mickle026 I took a look at my code, and I'm not using getElementById *anywhere*. I'm using page.querySelector("#IDGoesHere") everywhere. That probably means you need to switch to querySelector too, because I normally use getElementById in my javascript, so I'd only be using something different if Emby required me to. https://developer.mozilla.org/en-US/docs/Web/API/Document/querySelector So, I think it's *both* that you need to select through page *and* that you need to use querySelector instead of getElementById. Hopefully, that takes care of it. 1
Luke 42237 Posted September 19, 2022 Posted September 19, 2022 Also don't use the domcontentloaded event. Use the emby provided events related to the current view. 1
mickle026 653 Posted September 19, 2022 Author Posted September 19, 2022 (edited) @roakuI tried your code and it caused the page to load ontop of other pages, the image data did not load either However, A Massive THANK YOU!!! You have pointed me in the right direction function (loading) { return function (page) { var pluginUniqueId = "B19C4634-2C02-4DD9-8579-F950961EB219"; page.addEventListener('viewshow', () => { let headerElement = page.querySelector("#header"); ApiClient.getJSON(ApiClient.getUrl('CPP/MainHeader.html/LoadHTML')).then(response => { var dat = response; headerElement.innerHTML = dat.Text; console.log(dat.Text); }).catch(e => { console.log(e); }); // rest of page javascript } ); } } A slight modification and its now working on every page view !!! I cannot believe how much of a headache this was !!! Thank you Thank you Thank you !!! Edited September 19, 2022 by mickle026 2
chef 3811 Posted September 19, 2022 Posted September 19, 2022 24 minutes ago, Luke said: Also don't use the domcontentloaded event. Use the emby provided events related to the current view. Yeah, that was a hail Mary... No need for that.
mickle026 653 Posted September 19, 2022 Author Posted September 19, 2022 OMG! The images are now loading fine and everytime, but my collpasbile accordian html which is loaded in the same way from a file is now not working everytime!
chef 3811 Posted September 19, 2022 Posted September 19, 2022 (edited) 19 hours ago, chef said: Is all your code inside that API promise callback? Don't use document.getElementById Instead use: page.getElementById That way you are not querying the entire document. It might just be that. Oh my gosh... Edited September 19, 2022 by chef
chef 3811 Posted September 19, 2022 Posted September 19, 2022 2 minutes ago, mickle026 said: OMG! The images are now loading fine and everytime, but my collpasbile accordian html which is loaded in the same way from a file is now not working everytime! Make sure you are targeting the element correctly when you are querying the view. It is most likely the issue. Especially if you query an element, and then later do another query on that element to find a child. If that makes sense.
mickle026 653 Posted September 19, 2022 Author Posted September 19, 2022 (edited) 12 minutes ago, chef said: Make sure you are targeting the element correctly when you are querying the view. It is most likely the issue. Especially if you query an element, and then later do another query on that element to find a child. If that makes sense. Its not misbehaving in the same way, just to add to the issue ! If i page refresh, it works everytime If i click to go off the page its working 2 times in every 3. So its a similar problem, but its working 2 of the 3 times .. ffs! (as opposed to 1 in every 3) Its the 3rd instance its not working in, however it is loading! The according is loading everytime, like the images, just not working in the 3rd page instance. (expanding when i click it) Im going for a cuppa, jeez no wonder developers are stress heads! Edited September 19, 2022 by mickle026
mickle026 653 Posted September 19, 2022 Author Posted September 19, 2022 My accordian code, so to be clear the accorian is loading and showing in a collapsed state, its the expand thats not working in the 3rd page instance. <style> .hidecontent { display: none; } #myaccordion label { box-shadow:0 0 20px #d4d4d4; display: block; padding: 8px 22px; margin: 20px 0px 1px 0px; cursor: pointer; background: #5f75a4; color: #FFF; transition: ease .5s; } #myaccordion label:hover { background: #5f75ff; } .content { box-shadow:0 0 20px #d4d4d4; background: #ffff; padding: 10px 25px; border: 1px solid #d4d4d4; margin: -1 0 0 0; } #myaccordion input:checked + label + .content { display: block; webkit-animation: fadeIn 0.5s ease-out; -moz-animation: fadeIn 0.5s ease-out; -o-animation: fadeIn 0.5s ease-out; animation: fadeIn 0.5s ease-out; } @-webkit-keyframes fadeIn { 0% { display: none; opacity: 0; } 1% { display: block; opacity: 0; } 100% { display: block; opacity: 1; } } </style> <div id="myaccordion"> <input type="checkbox" id="accordion2" class="hidecontent"/> <label for="accordion2">Extra Information +</label> <div class="content hidecontent"> <p> content here </p> </div> Its greyed out in the inspector, so the input (essentially a styled checkbox) is unavaliable. This is similar behaviour to before with the images
roaku 842 Posted September 19, 2022 Posted September 19, 2022 2 minutes ago, mickle026 said: My accordian code, so to be clear the accorian is loading and showing in a collapsed state, its the expand thats not working in the 3rd page instance. <style> .hidecontent { display: none; } #myaccordion label { box-shadow:0 0 20px #d4d4d4; display: block; padding: 8px 22px; margin: 20px 0px 1px 0px; cursor: pointer; background: #5f75a4; color: #FFF; transition: ease .5s; } #myaccordion label:hover { background: #5f75ff; } .content { box-shadow:0 0 20px #d4d4d4; background: #ffff; padding: 10px 25px; border: 1px solid #d4d4d4; margin: -1 0 0 0; } #myaccordion input:checked + label + .content { display: block; webkit-animation: fadeIn 0.5s ease-out; -moz-animation: fadeIn 0.5s ease-out; -o-animation: fadeIn 0.5s ease-out; animation: fadeIn 0.5s ease-out; } @-webkit-keyframes fadeIn { 0% { display: none; opacity: 0; } 1% { display: block; opacity: 0; } 100% { display: block; opacity: 1; } } </style> <div id="myaccordion"> <input type="checkbox" id="accordion2" class="hidecontent"/> <label for="accordion2">Extra Information +</label> <div class="content hidecontent"> <p> content here </p> </div> Its greyed out in the inspector, so the input (essentially a styled checkbox) is unavaliable. This is similar behaviour to before with the images You're missing a closing div in this example html. 1
mickle026 653 Posted September 20, 2022 Author Posted September 20, 2022 The closing div doesn't fix the issue for the 3rd page instance, however now the images and html are loading from external files, I'll find a workaround that works eventually. Probably using a button to fire an API call to replace a div with response text/html. Thanks for your help @Luke,@roaku and @chef it is appreciated.
Luke 42237 Posted September 20, 2022 Posted September 20, 2022 22 minutes ago, mickle026 said: The closing div doesn't fix the issue for the 3rd page instance, however now the images and html are loading from external files, I'll find a workaround that works eventually. Probably using a button to fire an API call to replace a div with response text/html. That sounds like a good approach.
