DanielFrank 11 Posted September 17, 2022 Posted September 17, 2022 Hi there So, I recently began digitizing my old cartoons, and I'm also scanning all their covers. When uploading a cover to an item within Emby, the uploaded image it shows up sideways, even though the orientation has been adjusted in Windows. I've attached a screenshot of how the uploaded looks like within Emby, and uploaded the original image for everyone reference as well. Can anyone help with this, please? I have like 300 covers that I need to add to Emby, and this issue is preventing me from moving on.
Happy2Play 9814 Posted September 17, 2022 Posted September 17, 2022 I can assume the forum changed the resolution and corrected the issue as the attached image 712x1200 has correct orientation for me in Windows. You will probably have to zip the original and attach.
DanielFrank 11 Posted September 18, 2022 Author Posted September 18, 2022 10 hours ago, Happy2Play said: I can assume the forum changed the resolution and corrected the issue as the attached image 712x1200 has correct orientation for me in Windows. You will probably have to zip the original and attach. So, the image is just too large? I have to edit them to fit a certain size? That's just bad design. Would be cool if Emby could handle the resizing if needed, and provide options for rotating the uploaded image.
Happy2Play 9814 Posted September 18, 2022 Posted September 18, 2022 Without specifics of the original image, it is impossible to say. But the dimensions shown in first image appear to show that orientation, landscape not portrait.
DanielFrank 11 Posted September 18, 2022 Author Posted September 18, 2022 13 minutes ago, Happy2Play said: Without specifics of the original image, it is impossible to say. But the dimensions shown in first image appear to show that orientation, landscape not portrait. 0044_front.zipI understand. Here's a zip with the original image.
Happy2Play 9814 Posted September 18, 2022 Posted September 18, 2022 28 minutes ago, DanielFrank said: 0044_front.zipI understand. Here's a zip with the original image. @Luke will have to comment but the exif data shows it is rotated 90 degrees left. Spoiler create 2022-09-18T09:10:25+00:00 ExifOffset 4190 ExifVersion 48, 50, 51, 49 Orientation 6 modify 2022-09-18T09:10:25+00:00 ExifOffset 4190 ExifVersion 48, 50, 51, 49 Orientation 6 colorspace 2 ExifOffset 4190 ExifVersion 48, 50, 51, 49 Orientation 6 sampling-factor 2x2,1x1,1x1 ExifOffset 4190 ExifVersion 48, 50, 51, 49 Orientation 6
DanielFrank 11 Posted September 18, 2022 Author Posted September 18, 2022 2 minutes ago, Happy2Play said: @Luke will have to comment but the exif data shows it is rotated 90 degrees left. Reveal hidden contents create 2022-09-18T09:10:25+00:00 ExifOffset 4190 ExifVersion 48, 50, 51, 49 Orientation 6 modify 2022-09-18T09:10:25+00:00 ExifOffset 4190 ExifVersion 48, 50, 51, 49 Orientation 6 colorspace 2 ExifOffset 4190 ExifVersion 48, 50, 51, 49 Orientation 6 sampling-factor 2x2,1x1,1x1 ExifOffset 4190 ExifVersion 48, 50, 51, 49 Orientation 6 Dammit, Lightroom! Why would Emby rely on that data?
Happy2Play 9814 Posted September 18, 2022 Posted September 18, 2022 2 minutes ago, DanielFrank said: Dammit, Lightroom! Why would Emby rely on that data? Pretty sure exif data has been asked for Photos, but am guessing it applies to all images. But yes I believe there is a request for a rotate option in Emby also.
DanielFrank 11 Posted September 18, 2022 Author Posted September 18, 2022 Quote Pretty sure exif data has been asked for Photos I can understand that. Quote But yes I believe there is a request for a rotate option in Emby also. That would be very helpful, and I think that would save a lot of users a lot of time. It would for me.
Luke 42287 Posted September 23, 2022 Posted September 23, 2022 On 9/17/2022 at 4:55 PM, DanielFrank said: Hi there So, I recently began digitizing my old cartoons, and I'm also scanning all their covers. When uploading a cover to an item within Emby, the uploaded image it shows up sideways, even though the orientation has been adjusted in Windows. I've attached a screenshot of how the uploaded looks like within Emby, and uploaded the original image for everyone reference as well. Can anyone help with this, please? I have like 300 covers that I need to add to Emby, and this issue is preventing me from moving on. Is the image editor the only place with the incorrect orientation?
DanielFrank 11 Posted September 23, 2022 Author Posted September 23, 2022 1 hour ago, Luke said: Is the image editor the only place with the incorrect orientation? No, it's everywhere
Luke 42287 Posted September 24, 2022 Posted September 24, 2022 On 9/18/2022 at 5:17 AM, DanielFrank said: Dammit, Lightroom! Why would Emby rely on that data? Most photo viewing software will do that. I get that this isn't a photo, but that is the reason why.
