Luke 42241 Posted December 7, 2022 Posted December 7, 2022 14 minutes ago, XDavidT said: I’ve added it to movies folder but I cant see it on the tv Hi, where are you looking for it? How does the web app compare? Did you run a library scan?
XDavidT 15 Posted December 7, 2022 Author Posted December 7, 2022 6 minutes ago, Luke said: Hi, where are you looking for it? How does the web app compare? Did you run a library scan? Forgot to scan, thx. here is the logs and video IMG_2183.MOV ffmpeg-transcode-2525136f-5d37-4684-a595-31c68965aac1_1.txt ffmpeg-transcode-38b1c06f-712c-4306-9527-232040c3a5ec_1.txt ffmpeg-transcode-3142f3cb-541b-4a5e-880d-c43be97cf565_1.txt embyserver.txt 1
SamES 1084 Posted December 8, 2022 Posted December 8, 2022 Sorry, I think I must have sent you the wrong link. That file didn't have an audio track which has messed up our test. Can you please try this one? It's a little longer, but not huge. It should DirectPlay http://distribution.bbb3d.renderfarming.net/video/mp4/bbb_sunflower_1080p_30fps_normal.mp4
XDavidT 15 Posted December 20, 2022 Author Posted December 20, 2022 On 12/8/2022 at 1:05 PM, SamES said: Sorry, I think I must have sent you the wrong link. That file didn't have an audio track which has messed up our test. Can you please try this one? It's a little longer, but not huge. It should DirectPlay http://distribution.bbb3d.renderfarming.net/video/mp4/bbb_sunflower_1080p_30fps_normal.mp4 sorry for the late reply- but I've tried to check this one today but emby app not open since "Validation has expired" Do I need to get a new zip of emby for samsung?
Luke 42241 Posted December 20, 2022 Posted December 20, 2022 21 minutes ago, XDavidT said: sorry for the late reply- but I've tried to check this one today but emby app not open since "Validation has expired" Do I need to get a new zip of emby for samsung? Hi, yes you do.
XDavidT 15 Posted December 20, 2022 Author Posted December 20, 2022 6 minutes ago, Luke said: Hi, yes you do. The last one you custom made, I tried to install it again with same results
Luke 42241 Posted December 20, 2022 Posted December 20, 2022 46 minutes ago, XDavidT said: The last one you custom made, I tried to install it again with same results Which last one? When did you download it?
SamES 1084 Posted December 21, 2022 Posted December 21, 2022 8 hours ago, XDavidT said: The last one you custom made, I tried to install it again with same results You can just use the standard USB download, we don't need the custom one now, that was just for test. Thanks
XDavidT 15 Posted December 22, 2022 Author Posted December 22, 2022 On 12/21/2022 at 7:31 AM, SamES said: You can just use the standard USB download, we don't need the custom one now, that was just for test. Thanks Thx, I've just installed the last one, and seem subtitles working now!! But sorry to be the bad news, I've tried first to go into stats for nerds, but I can't go up on the menu, but it's another new bug. https://photos.app.goo.gl/9DJ43Wau4rnK3MXP9 1
SamES 1084 Posted December 22, 2022 Posted December 22, 2022 2 hours ago, XDavidT said: Thx, I've just installed the last one, and seem subtitles working now!! But sorry to be the bad news, I've tried first to go into stats for nerds, but I can't go up on the menu, but it's another new bug. https://photos.app.goo.gl/9DJ43Wau4rnK3MXP9 Great, sounds like we found the problem, thanks for your help. @Luke are you aware of any recent issues or changes that would cause issues navigating to the control line above the progress bar on the OSD? I've not seen it reported anywhere, but you may have fixed it already.
XDavidT 15 Posted December 22, 2022 Author Posted December 22, 2022 58 minutes ago, SamES said: Great, sounds like we found the problem, thanks for your help. @Luke are you aware of any recent issues or changes that would cause issues navigating to the control line above the progress bar on the OSD? I've not seen it reported anywhere, but you may have fixed it already. I don't think he fixed it, since I downloaded today the latest version
SamES 1084 Posted December 22, 2022 Posted December 22, 2022 18 minutes ago, XDavidT said: I don't think he fixed it, since I downloaded today the latest version It might be fixed on other platforms but not yet updated in the Samsung client, that’s what I meant. Sorry for the confusion.
