XDavidT 15 Posted September 17, 2022 Posted September 17, 2022 Under each movie/tv show, there a few languages, but they aren't wanted. Under the library the subtitles wasn't selected. And each movie have a local subtitle in the folder from the source of my download, so it's not needed. How to disable it and prefer only the local file ? (also shows as 'und')
Solution Luke 42186 Posted September 17, 2022 Solution Posted September 17, 2022 Hi, those are subtitles embedded into your video files. Emby did not download those.
XDavidT 15 Posted September 17, 2022 Author Posted September 17, 2022 2 minutes ago, Luke said: Hi, those are subtitles embedded into your video files. Emby did not download those. So it's came from the file I've downloaded? no way to ignore them or show first the local file I have in the folder?
Luke 42186 Posted September 17, 2022 Posted September 17, 2022 5 minutes ago, XDavidT said: So it's came from the file I've downloaded? no way to ignore them or show first the local file I have in the folder? Yes those are part of the file. There are currently no options to ignore or change the order of them. 2
olympus1 46 Posted September 17, 2022 Posted September 17, 2022 1 minute ago, Luke said: Yes those are part of the file. There are currently no options to ignore or change the order of them. It would be convenient if there was an option to make Emby not to show the embedded subtitles. I think it has been requested before. I could remux my files and remove them, but I don't want to do that because I want to use them in other players like MPC-HE or MPV. I always put an external subtitle for Emby in every file because I want to avoid the extraction process of an embedded subtitle. So I end up with a subtitle option with 2 subtitles of the same language in Emby, the external and the embedded, a subtitle I want to avoid having even as an option in Emby. Please consider this as a possible option in future, in my humble opinion many people would welcome an option to "get rid" the embedded subtitles without having to remux their files. 1 1
Bottles51 74 Posted September 18, 2022 Posted September 18, 2022 (edited) Mkv tool nix does a good job of this and only take a few seconds (If the file is on the same device as the program). If your original file is a mkv file you will be changing nothing. Edited September 18, 2022 by Bottles51
