Locutus64 125 Posted September 21, 2022 Posted September 21, 2022 I said nothing about either TVDB or TMDB being unchecked.
Happy2Play 9814 Posted October 7, 2022 Posted October 7, 2022 4 minutes ago, Luke said: @Happy2Playwhat do you make of this? Not sure the exact question here but if about provider order I believe TMDB should be first provider by default. Also mentioned in another to about possible stop using TVDB externalids for TMDB as there have been multiple topics of issues with TVDB having wrong TMDB ids.
Locutus64 125 Posted October 10, 2022 Posted October 10, 2022 20 hours ago, Luke said: @Locutus64 does that sound right? Yes for movie libraries TMDB should be first not TVDB, which is what I said. As for the second part of @Happy2Play's post I have no idea. Personally across the board I'd make TMDB first cause it is more accurate even for TV series and specials than TVDB is.
Happy2Play 9814 Posted October 10, 2022 Posted October 10, 2022 Personally, don't use TMDB for TV, but as these are configurable order would come down to a personal preference. But one could say by default only TMDB enabled on Movies and only TVDB enabled on TV Shows library content type template.
Luke 42290 Posted April 12, 2023 Posted April 12, 2023 An unmatch feature is coming in Emby Server 4.8: 1 2
