starisme 5 Posted September 16, 2022 Posted September 16, 2022 I've been experiencing weird issues with PGS subs where the stream won't play on the client but on the server dashboard it says its streaming to the client. This happens intermittently where certain movies and with certain PGS subs cause this issue. The most consistent way to get to happen is on iOS. I've attached the server and transcode logs as well. Does anyone know if this is a known issue? ffmpeg-transcode-adec2eb2-8676-4fdf-97c1-321f222c5ba3_1.txt embyserver.txt
Luke 42241 Posted October 5, 2022 Posted October 5, 2022 Hi, @softworkz is looking into this. Thanks.
softworkz 5133 Posted November 2, 2022 Posted November 2, 2022 @starisme - the kind of issues are fixed in the latest beta versions. If you wouldn't mind to try a beta version, you could install the latest beta. The fixes will also be included in 4.8.x stable versions once available. Thanks, sw
