nodiaque 62 Posted October 16, 2013 Posted October 16, 2013 Hello,There seems to be a problem with the lockdata feature when set to true (from disabling "Enable internet metadata providers for this item".I've download metadata in french for many tv shows and movies. One by one, I disabled this option after fetching them. For tv series, since I wasn't sure if I did it at season and root level(is it needed to disable fetching for each season and episode or disabling at root folder, where all seasons are, is enough?).Once everything is good, I change my metadata langage back to english. Everything is done through mb webclient.After doing all this, I can see there's a lock icon next to the title when editing metadata.Now, 2 things I think is bugged:1) all my metadata that were in french got redownloaded back in english for all root, seasons and episodes, even with the lock icon and hacing disabled metadata fetching on them.2) If I force refresh, with internet metadata, it still download it from internet for the active item and all child item, even if they too have lock metadata and internet metadata disabled. Funny thing, it does say this under force refresh: A force refresh will cause internet metadata to be re-downloaded (if enabled, and dependent on metadata settings). For me, that mean if I disabled metadata fetching for this item, it won't redownload it. At least, that's how I understand. But it seems to refer to global metadata settings, thus making the option in the item useless.Thanks Version 3.0.5031.21343 MB Server
Luke 42287 Posted October 16, 2013 Posted October 16, 2013 You are correct. Sounds like a bug. I'll test it out.
nodiaque 62 Posted October 16, 2013 Author Posted October 16, 2013 ok, glad I could help found one Just for my information, if I lock a metadata on a folder, does it imply that all subfolders and file are lock too? Because right now, I manually lock everything to see the lock icon on the left. I think it should lock everything under since you lock the parent folder.
nodiaque 62 Posted November 6, 2013 Author Posted November 6, 2013 Did you found the problem? Because auto fetch still update all my tv show that have been locked, changing there langage.
WarrenH 16 Posted November 6, 2013 Posted November 6, 2013 You need to lock metadata at each episode level
johnchimpo 7 Posted November 7, 2013 Posted November 7, 2013 You need to lock metadata at each episode level Perhaps an option to lock at the series/season/folder level should be implemented. 1
nodiaque 62 Posted November 7, 2013 Author Posted November 7, 2013 funny thing is all my locked season and episode still get updated... and there is a lock at season/series level, but it doesn't seems to do anything.
Luke 42287 Posted November 7, 2013 Posted November 7, 2013 I will put this on my review list for an upcoming release. (Not the next one).
