dieffe70 9 Posted September 15, 2022 Posted September 15, 2022 Hi, I use My DDNS function from myqnap cloud link for accessing my nas from outside and this work good except that with Emby free server. My Ip is almost always the same it rarely changes but when this happen I can't connect with Emby from outside, server is unreachable as if the DDNS isn't working good.. but from QNAP admin I can see the new IP is updated correctly and I can reach other services based on DDNS. Emby won't work until I'll come back to my usual IP. It seems that hostname for the NAS work only with original IP. Any idea? Thanks
Luke 42239 Posted September 15, 2022 Posted September 15, 2022 Hi, did you try configuring the ddns address as your remote address in emby server network settings?
dieffe70 9 Posted September 16, 2022 Author Posted September 16, 2022 12 hours ago, Luke said: Hi, did you try configuring the ddns address as your remote address in emby server network settings?
dieffe70 9 Posted September 16, 2022 Author Posted September 16, 2022 Yes sure, otherwise I would not be able to connect from remote. Infact I connect mostly with no issues from anyware via SSL also. But if my router leave the usual IP then Emby it's not reachable anymore from outside, even if my DDNS hostname it's correctly redirecting me to the right IP. This happening only with Emby service
Luke 42239 Posted September 16, 2022 Posted September 16, 2022 5 hours ago, dieffe70 said: Yes sure, otherwise I would not be able to connect from remote. Infact I connect mostly with no issues from anyware via SSL also. But if my router leave the usual IP then Emby it's not reachable anymore from outside, even if my DDNS hostname it's correctly redirecting me to the right IP. This happening only with Emby service What exactly did you configure?
dieffe70 9 Posted September 16, 2022 Author Posted September 16, 2022 In Lan settings I've put my DDNS hostname (mynas.myddns.com) in remote address field, and as I said all works like a charm until my IP doesn't change. While QNAP services based on DDNS still continue to work (as expected). Emby it's not reachable from outside until connection swtich back to my usual IP.
Luke 42239 Posted September 16, 2022 Posted September 16, 2022 Does your emby server dashboard display the ddns url as your remote address?
dieffe70 9 Posted September 16, 2022 Author Posted September 16, 2022 Yes sure. Remote Access WAN shows https:mynas.myddns.com:myport and I can reach it easily. Except when IP changes
Luke 42239 Posted September 16, 2022 Posted September 16, 2022 What Emby app are you connecting from? How are you establishing the connection?
dieffe70 9 Posted September 16, 2022 Author Posted September 16, 2022 (edited) Emby for Android. Emby for Lg TV. Emby Samsung TV, web browser.. all working like expected but they all stop to work because hostname don't go where it should guess Edited September 16, 2022 by dieffe70
keithsrobertson 11 Posted September 16, 2022 Posted September 16, 2022 Have a look at my post to see if that helps:
dieffe70 9 Posted September 19, 2022 Author Posted September 19, 2022 Well thanks surely your guide is helpful, but fortunately all my DDNS and SSL setup work perfectly. I'm using the qnap natural DDNS service and the built in SSL certificate from let's encrypt. And I can always reach my NAS from wherever. Only with Emby if usual IP is changed I have problem in connecting to server, while other NAS services still are ok
Luke 42239 Posted September 19, 2022 Posted September 19, 2022 On 9/16/2022 at 1:27 PM, dieffe70 said: Emby for Android. Emby for Lg TV. Emby Samsung TV, web browser.. all working like expected but they all stop to work because hostname don't go where it should guess I wonder if they are connecting by IP and not host name. How did you establish the initial connection?
dieffe70 9 Posted September 19, 2022 Author Posted September 19, 2022 all my devices connect via hostname. That's how I've set first connection. Manual settings of hostname+port then credentials
dieffe70 9 Posted October 7, 2022 Author Posted October 7, 2022 Actually the IP remained fixed for long time so the issue did not happened anymore 1
sjkiss 28 Posted October 30, 2022 Posted October 30, 2022 I think this is exactly my problem. @dieffe70How do you ensure your IP address stays fixed? Can you walk me through your exact set up?
