ZeeNetTV 4 Posted September 15, 2022 Posted September 15, 2022 (edited) Added a few new episodes to my TV series library, and it wouldn't take for some reason. Now, nothing I add to TV series library will take correctly. Keeps getting stuck at 92%. My movie library is fine, is taking new movies added like it should. I have changed absolutely no settings. It was fine one moment, then not fine the next. All files are appropriately named. Starting to think I'm going to have re-build the TV library from scratch, though I shouldn't really be having to. Could one bad file have corrupted my entire tv library?? It doesn't even want to do a manual scan anymore either. Edited September 15, 2022 by ZeeNetTV
Luke 42239 Posted September 15, 2022 Posted September 15, 2022 Hi there, I would just be patient and allow the scan to finish. Please let us know if this helps. Thanks.
Happy2Play 9811 Posted September 16, 2022 Posted September 16, 2022 We would need to see the server log if media is not seen when scan finishes.
ZeeNetTV 4 Posted September 30, 2022 Author Posted September 30, 2022 I ended up rebuilding the entire library. It still has some issues. I would post server logs, but there's none to post. Whenever it backfires, it doesn't "log" anything, just acts like nothing happened. Eh, it's working (mostly)...
Luke 42239 Posted September 30, 2022 Posted September 30, 2022 Just now, ZeeNetTV said: I ended up rebuilding the entire library. It still has some issues. I would post server logs, but there's none to post. Whenever it backfires, it doesn't "log" anything, just acts like nothing happened. Eh, it's working (mostly)... Hi, there is always a server log file, and almost always something we can learn from it.
