RTVstyle 1 Posted September 15, 2022 Posted September 15, 2022 Hi IOS 2.2.5 has an error in the support of ac3 audio track. As long as a movie with ac3 audio track is played, it will prompt: "Playback error: no compatible stream". The same video can be played normally on the emby client of Macos and TV OS. No error will be prompted for other formats of audio tracks, DTS and Truehd audio tracks that were not supported before are supported. Please check to see if this is really the case.
Luke 42241 Posted September 15, 2022 Posted September 15, 2022 @RTVstyle Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
cuonghv 0 Posted September 16, 2022 Posted September 16, 2022 Yes. Me too. AC3 audio track is very popular. Please fix this error soon.
Luke 42241 Posted September 16, 2022 Posted September 16, 2022 Can we please look at an example? It seems to be working just fine in my testing.
cuonghv 0 Posted September 16, 2022 Posted September 16, 2022 (edited) Audio: AC3 direct play but container MKV not direct play and server converted to HLS to play. Edited September 16, 2022 by cuonghv
RTVstyle 1 Posted September 17, 2022 Author Posted September 17, 2022 12 hours ago, Luke said: 我们可以看一个例子吗?在我的测试中,它似乎工作得很好。 thanks for the reply! To be more specific, Emby for IOS 2.2.5, when playing MKV-packaged video, as long as the ac3 audio track is used, it will prompt a playback error, and the same video can be played normally by replacing the audio track of other formats. Playing with non-IOS devices will play normally. So, this problem doesn't seem to be related to the server, it's a pure IOS 2.2.5 version problem.
Luke 42241 Posted September 21, 2022 Posted September 21, 2022 @RTVstyle Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
RTVstyle 1 Posted September 23, 2022 Author Posted September 23, 2022 OK, thank you.attach log embyserver.txt ffmpeg-transcode-32fac16e-0213-4fde-a010-813638d4a27f_1.txt ffmpeg-transcode-6932da59-0b1b-440a-a545-0e2bd1953120_1.txt
Luke 42241 Posted October 10, 2022 Posted October 10, 2022 On 10/6/2022 at 6:48 PM, Kthan221 said: Has the problem been solved ? Hi, we are looking into this. Thanks.
Luke 42241 Posted October 27, 2022 Posted October 27, 2022 Hi, can we get some of you to join the iOS beta and let me know if this is resolved? Please follow the instructions here: Thanks !
frylich 9 Posted October 28, 2022 Posted October 28, 2022 20 hours ago, Luke said: Hi, can we get some of you to join the iOS beta and let me know if this is resolved? Please follow the instructions here: Thanks ! Hello Luke, I would like to test the beta, unfortunately, I'm still waiting for a friend to lend me an ipad... 1
RTVstyle 1 Posted November 11, 2022 Author Posted November 11, 2022 I use the IOS beta version to test, this bug is gone. thank you all.
Luke 42241 Posted November 13, 2022 Posted November 13, 2022 Thanks, we'll get it released next week hopefully.
Luke 42241 Posted February 4, 2023 Posted February 4, 2023 HI, Emby for iOS 2.2.6 has been released. Please try it out and let us know how it compares. Thanks !
