Houfino 41 Posted September 14, 2022 Posted September 14, 2022 (edited) Hi..I have a problem with synolog..I solved with @Happy2Play 14 days ago...Solved, but unfortunately NFO doesn't work for me when I add new videos..It only shows .bif and there is no NFO,PHOTO(cellar logo, fan art, poster).It seems that .bif probably has a problem and blocks scanning for NFO..What is going on? THANK YOU.. I solved it with Happy2play.. OK, but I still have a problem with NFO Sample minutes image video Synology: DS216play DSM 7.1-42661 Update 4 Edited September 15, 2022 by Houfino
Houfino 41 Posted September 14, 2022 Author Posted September 14, 2022 2 hours ago, Houfino said: Hi..I have a problem with synolog..I solved with @Happy2Play 14 days ago...Solved, but unfortunately NFO doesn't work for me when I add new videos..It only shows .bif and there is no NFO,PHOTO(cellar logo, fan art, poster).It seems that .bif probably has a problem and blocks scanning for NFO..What is going on? THANK YOU.. I solved it with Happy2play.. OK, but I still have a problem with NFO Sample minutes image video Synology: DS216play DSM 7.1-42661 Update 4 Nobody knows?
Luke 42243 Posted September 14, 2022 Posted September 14, 2022 Hi there, have you tried refreshing the metadata on this title?
Happy2Play 9812 Posted September 14, 2022 Posted September 14, 2022 If that does not work, you will need to provide the server log showing the refresh.
Houfino 41 Posted September 14, 2022 Author Posted September 14, 2022 @Luke: Yes...I restored and now it's running at 94%....Let's see if ok... @Happy2Play : Wait..When it's 100% done, I'll let you know... Â 1
Houfino 41 Posted September 15, 2022 Author Posted September 15, 2022 Working and fine..Thank you.. I must have set it wrong... I had to check it and it works... Why? Because I deleted the library and added a new library, so I didn't check the settings....Now OK Thank you 1
