iamspartacus 40 Posted September 13, 2022 Posted September 13, 2022 Is there any way to have the auto generated library images recreated after removing a previously manually set image?
iamspartacus 40 Posted September 13, 2022 Author Posted September 13, 2022 Just now, Luke said: Hi, yes, just run a library scan. I've done that multiple times as well as rebooted and refreshed metadata. Nothing has worked.
Happy2Play 9798 Posted September 13, 2022 Posted September 13, 2022 Just now, iamspartacus said: I've done that multiple times as well as rebooted and refreshed metadata. Nothing has worked. Can you restart Emby or rotate logs vis Scheduled task and do a library scan and post the server log.
iamspartacus 40 Posted September 13, 2022 Author Posted September 13, 2022 3 minutes ago, Happy2Play said: Can you restart Emby or rotate logs vis Scheduled task and do a library scan and post the server log. Yes. Will do.
Solution iamspartacus 40 Posted September 14, 2022 Author Solution Posted September 14, 2022 (edited) Ok in reviewing the logs I found the error. I had an old path that no longer exists. Removing that and doing a rescan fixed it. Edited September 14, 2022 by iamspartacus 1
AngelMovies 0 Posted December 20, 2024 Posted December 20, 2024 On 9/14/2022 at 9:49 AM, iamspartacus said: Ok in reviewing the logs I found the error. I had an old path that no longer exists. Removing that and doing a rescan fixed it. Could you explain to me how you did this?
Happy2Play 9798 Posted December 20, 2024 Posted December 20, 2024 (edited) 1 hour ago, AngelMovies said: Could you explain to me how you did this? Can you post a server log for your issue but is should be as easy as running a full library scan. As I just deleted the current one and performed a library scan to create a new one. Edited December 20, 2024 by Happy2Play
