snake98 10 Posted September 12, 2022 Posted September 12, 2022 Just checking to see if anyone can use atsc 3.0 through emby on the lg app. The only way I can get it working to force trans-coding to a lower bitrate.
Luke 42234 Posted September 12, 2022 Posted September 12, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
snake98 10 Posted September 21, 2022 Author Posted September 21, 2022 Okay, attached are all the log files. I can get it to work on atsc 3.0 if I set a bit rate limit, example 10. it will play and trans-code fine, when I set it to auto, i just get a black screen. Details. Windows 10 pro Emby version 4.7.6.0 LG, current version. OLED77cxpua hardware trans-coding disabled. Trying to get atsc 3.0 to work without forcing rate limit. ffmpeg-transcode-3fafd531-dfe4-4b3e-a007-b503e1b1d770_1.txt ffmpeg-transcode-d717af1a-e44e-4ebe-9a47-06a98d8bd8cb_1.txt embyserver(2).txt ffmpeg-remux-4824ea11-a236-434d-be0b-142d67ea3ade_1.txt ffmpeg-transcode-cdb7ccee-f4a7-4e9e-ad67-1b8124a05834_1.txt ffmpeg-remux-d1a04163-0f37-495e-9db7-226af5d2a996_1.txt ffmpeg-remux-649ca156-7eb1-469c-9ceb-a5595a9b3c45_1.txt ffmpeg-remux-1e7614dc-03cb-4933-bca5-35f7868b58b2_1(1).txt ffmpeg-remux-1e7614dc-03cb-4933-bca5-35f7868b58b2_1.txt ffmpeg-remux-da24129f-05f8-4872-b3b1-418727c7b111_1.txt ffmpeg-remux-ab8d7674-3511-4471-bd43-afe327e2fdab_1.txt ffmpeg-remux-a70476ff-5d52-455e-95cd-36c2771b0993_1.txt ffmpeg-remux-c9502182-d314-4523-9e3d-82a4fda54e58_1.txt ffmpeg-remux-5556aa9b-6fbd-4b60-88d0-f10853fd82f8_1.txt ffmpeg-transcode-14108711-e74f-4ccd-a693-5c9e80f4c1be_1.txt
snake98 10 Posted September 25, 2022 Author Posted September 25, 2022 Just following up, I think i included everything you need.
snake98 10 Posted October 17, 2022 Author Posted October 17, 2022 Any hope on this, or is atsc 3.0 not supported on lg tv through emby.
Luke 42234 Posted October 17, 2022 Posted October 17, 2022 Hi, it is resolved for the next update to the emby LG app. Thanks.
Luke 42234 Posted December 26, 2022 Posted December 26, 2022 Emby for LG TV's 1.0.37 has been released. Stay tuned to the blog for the release announcement. Can you please try out the new update and let us know how it compares? Thanks !
snake98 10 Posted January 9, 2023 Author Posted January 9, 2023 Tried the new update, did not fix it. logs included embyserver(3).txt ffmpeg-transcode-2ee236c8-1d61-49a3-ab2e-b17102a30df2_1.txt ffmpeg-transcode-8af5e270-d1e6-4922-b0a0-a57e7bb47fd7_1.txt ffmpeg-transcode-9ad0a2a4-ed65-43c5-89d7-ff2484f7fadf_1.txt ffmpeg-transcode-034feea9-370f-4464-9e8a-03f91edc860f_1.txt ffmpeg-transcode-b9b5b7c1-5f04-4413-86b8-6df2cf38c290_1.txt ffmpeg-transcode-dc717923-63bf-4741-85b2-1e8c89a760e0_1.txt
Luke 42234 Posted January 18, 2023 Posted January 18, 2023 On 1/8/2023 at 8:17 PM, snake98 said: Tried the new update, did not fix it. logs included embyserver(3).txt 335.28 kB · 0 downloads ffmpeg-transcode-2ee236c8-1d61-49a3-ab2e-b17102a30df2_1.txt 18.71 kB · 0 downloads ffmpeg-transcode-8af5e270-d1e6-4922-b0a0-a57e7bb47fd7_1.txt 18.25 kB · 0 downloads ffmpeg-transcode-9ad0a2a4-ed65-43c5-89d7-ff2484f7fadf_1.txt 18.72 kB · 0 downloads ffmpeg-transcode-034feea9-370f-4464-9e8a-03f91edc860f_1.txt 11.14 kB · 0 downloads ffmpeg-transcode-b9b5b7c1-5f04-4413-86b8-6df2cf38c290_1.txt 10.18 kB · 0 downloads ffmpeg-transcode-dc717923-63bf-4741-85b2-1e8c89a760e0_1.txt 9.68 kB · 0 downloads What exactly happened?
snake98 10 Posted January 19, 2023 Author Posted January 19, 2023 (edited) it never starts to play on the tv. The only way I can get it work is to limit the bandwidth to force trans-coding. Edited January 19, 2023 by snake98 1
snake98 10 Posted January 24, 2023 Author Posted January 24, 2023 Is there any other info or files you need?
Luke 42234 Posted February 21, 2023 Posted February 21, 2023 Hi, I believe this should be resolved in the upcoming 4.8 server release. Thanks.
