Luke 42237 Posted March 19, 2024 Posted March 19, 2024 On 3/16/2024 at 2:12 AM, kakashi55 said: Hi, is there any update to this issue ? I am running Emby Server 4.9.0.4 on Android 12 phone. Emby can't access USB OTG hdd/ssd. Thanks. Can you install XPlore? Are you able to locate the usb with that?
alok1 14 Posted March 20, 2024 Posted March 20, 2024 On 3/19/2024 at 11:10 AM, Luke said: Can you install XPlore? Are you able to locate the usb with that? All file managers can locate USB Storage. The problem lies with the server. 'Emby Server for Android' lacks MANAGE_EXTERNAL_STORAGE permission. I gave this permission to Emby server by editing AndroidManifest.xml and using a adb command. Now, Emby Server can also access USB Storage. I request Emby team to add this permission in upcoming updates. Thanks.
Luke 42237 Posted March 20, 2024 Posted March 20, 2024 2 hours ago, kakashi55 said: All file managers can locate USB Storage. The problem lies with the server. 'Emby Server for Android' lacks MANAGE_EXTERNAL_STORAGE permission. I gave this permission to Emby server by editing AndroidManifest.xml and using a adb command. Now, Emby Server can also access USB Storage. I request Emby team to add this permission in upcoming updates. Thanks. Hi, what version of android is your device on?
alok1 14 Posted March 20, 2024 Posted March 20, 2024 (edited) 10 minutes ago, Luke said: Hi, what version of android is your device on? I am on Android 12. Emby has Read_External_Storage and Write_External_Storage permissions. But on newer Android versions, it also needs Manage_External_Storage permission. Edited March 20, 2024 by kakashi55 1
nmh.1994@gmail.com 0 Posted April 8, 2024 Posted April 8, 2024 On 3/20/2024 at 11:52 PM, kakashi55 said: All file managers can locate USB Storage. The problem lies with the server. 'Emby Server for Android' lacks MANAGE_EXTERNAL_STORAGE permission. I gave this permission to Emby server by editing AndroidManifest.xml and using a adb command. Now, Emby Server can also access USB Storage. I request Emby team to add this permission in upcoming updates. Thanks. can you share your apk file please, I have 1TB NTFS HDD usb and i want to use my old pixel 4xl phone as emby server too, the hard part is to get emby see my USB and add it to library i can downgrade pixel from android 13 to 10 or install custom rom but seem ntfs need to mount through paragon app, please help me sir
alok1 14 Posted April 8, 2024 Posted April 8, 2024 (edited) 1 hour ago, nmh.1994@gmail.com said: but seem ntfs need to mount through paragon app, Paragon app won't work because it doesn't actually mount usb drives. Paragon app works as document provider and emby server doesn't use 'Storage access Framework'. So it won't work. Solution --- You have to root your phone using Magisx and install NTFS-3g Magisx Module. https://github.com/woa-vayu-archive/Port-Windows-11-POCO-X3-Pro/releases/download/ntfsdroid/ntfs3g.zip Use a file manager to navigate to /dev/block/ and have a look at all your hdd partitions. They will be listed as sda1, sda2, sda3 etc. Make a folder in internal storage where you will mount your partitions such as partition1, partition2, partition3 etc.. Use termux app and enter below command to mount the desired partition of your hdd: su -mm -c "mount.ntfs /dev/block/sd*1 /storage/emulated/0/partition1" Use sd*2, sd*3 , partition2, partition3 in above command as per your need. Enter below command to unmount: su -mm -c umount /storage/emulated/0/partition1 I used * because sda can also change to sdb, sdc etc, if you unplug and replug your hdd. Since you are mounting hdd to internal storage i.e. /storage/emulated/0, you don't need to modify Emby server apk to add 'Manage_External_Storage' permission. Emby server already has r/w access at that location. Extra Tip: use a Powered USB hub. Stock Android doesn't support NTFS. But many phones such as Mi, Samsung , OnePlus already have NTFS support built-in. So, no need to root these phones. In that case, Emby server only requires 'Manage_External_Storage' permission to access USB drives and SD cards. @LukeTherefore, I would request emby team to add 'Manage External storage' permission in Emby server for Android. All file managers have this permission in Android 11 and above. With this permission, emby server will be able to access all files in SD cards and USB drives. No need to implement SAF(storage access framework). I don't think It would take more than 30 minutes to implement this permission. Thanks. Edited April 8, 2024 by kakashi55
nmh.1994@gmail.com 0 Posted April 9, 2024 Posted April 9, 2024 9 hours ago, kakashi55 said: enter below command to mount the desired partition of your hdd: su -mm -c "mount.ntfs /dev/block/sd*1 /storage/emulated/0/partition1" thanks you so much for helping, mount ntfs is the best method i tried that command but it says "failed to access mount point /storage/emulated/0/partition1: No such file or directory" then i create a folder named Movies then try su -mm -c "mount.ntfs /dev/block/sdg1 /storage/emulated/0/Movies" it does mount my hdd to a Movies file, total commander can see my hdd in this file but when go to emby it does not accept that /storage/emulated/0/Movies (the path could not be found) i think maybe need to add some mount option to android accept my hdd as a folder
nmh.1994@gmail.com 0 Posted April 9, 2024 Posted April 9, 2024 ahha i get it worked Firstly, SElinux must be set to permissive su setenforce 0 su -mm -c “mount.ntfs /dev/block....
alok1 14 Posted April 9, 2024 Posted April 9, 2024 5 hours ago, nmh.1994@gmail.com said: failed to access mount point /storage/emulated/0/partition1 Did you create partition1 folder ? 32 minutes ago, nmh.1994@gmail.com said: SElinux must be set to permissive I didn't have to set SElinux to permissive. 5 hours ago, nmh.1994@gmail.com said: mount.ntfs /dev/block/sdg1 Use sd*1 instead of sdg1. And make scripts such as mount.sh and unmount.sh and put your commands inside these scripts and use termux-widget app, then you can just click on home screen icons to mount, unmount the hdd. Cheers ! 1
NEONEO 0 Posted December 13, 2024 Posted December 13, 2024 @Luke Dear Luke, I probably came across the same problem today. I try to use my old cellphone Meizu17, having a system based on Android 13 and failed to input any kind of mobile storage path (ie. /mnt/media_rw/0C62104D0C62104D/media/TV SD). The internal storage path in my cellphone are totally fine(ie. /storage/emulated/0/...). Only got problem with the mobile storage device. I have tried different cell phones and storage devices and finally located the problem--'/mnt/....'. Everything is going well as long as having a path starting with "/storage/..."It seems that emby still can't read the 'mnt' path because of the 'Manage External storage' permission mentioned above. May i know did you finish the permission adding or i am just having a different problem? Can you help to solve it? Thanks. Look forward to your reply
Luke 42237 Posted December 13, 2024 Posted December 13, 2024 Hi, the change is on the 4.9 beta channel. We'll include it in the next 4.8.x release. Thanks.
NEONEO 0 Posted December 13, 2024 Posted December 13, 2024 49 minutes ago, Luke said: Hi, the change is on the 4.9 beta channel. We'll include it in the next 4.8.x release. Thanks. Dear Luke, thanks for your quick reply. After checking your message, I installed the 4.9.0.32 beta version at once.But the problem was not solved still. Is there any other steps that I should adapt? Or I may just wait for the releasing of 4.8.x version?
Luke 42237 Posted January 3, 2025 Posted January 3, 2025 Hi, did you figure this out? @Carlomay also have some tips.
alok1 14 Posted January 3, 2025 Posted January 3, 2025 On 12/13/2024 at 5:52 PM, NEONEO said: May i know did you finish the permission adding or i am just having a different problem? Can you help to solve it? Hi, 'MANAGE EXTERNAL STORAGE' permission has not been added yet. I can confirm. I am using --- Emby server for Android version - 4.9.0.34-Beta
Luke 42237 Posted January 3, 2025 Posted January 3, 2025 4 minutes ago, kakashi55 said: Hi, 'MANAGE EXTERNAL STORAGE' permission has not been added yet. I can confirm. I am using --- Emby server for Android version - 4.9.0.34-Beta Hi, you can confirm how? it is in the manifest.
alok1 14 Posted January 3, 2025 Posted January 3, 2025 (edited) 33 minutes ago, Luke said: Hi, you can confirm how? it is in the manifest. Yeah, but AndroidManifest.xml can be easily seen by unpacking the apk. Also, when an app has this permission, then it asks for 'All file access' as shown in screenshot below, but Emby server doesn't ask for it. The solution is to add 'Manage_External_Storage' permission as suggested 8 months ago. As a workaround, I have currently added this permission by modifying the APK, adding it to the AndroidManifest.xml, and using a command via ADB. Hope it helps @NEONEO@Luke Edited January 3, 2025 by kakashi55
Luke 42237 Posted January 9, 2025 Posted January 9, 2025 What is the process you are using to examine the manifest?
Brainsie 0 Posted January 10, 2025 Posted January 10, 2025 On 1/9/2025 at 3:57 AM, Luke said: What is the process you are using to examine the manifest? If you decompile the APK via APK Tool you can see that the manifest doesn't include the Manage_External_Storage. I tried to add it myself, but the APK then doesn't work after I launch it. Can the dvelopers add the following line to the manifest? <uses-permission android:name="android.permission.MANAGE_EXTERNAL_STORAGE"/>
alok1 14 Posted January 10, 2025 Posted January 10, 2025 2 hours ago, Brainsie said: I tried to add it myself, but the APK then doesn't work after I launch it I think you missed the part where I mentioned about adb command. After adding permission in manifest, just run below adb command while your phone is connected to pc with USB debugging on. adb shell appops set --uid com.emby.embyserver MANAGE_EXTERNAL_STORAGE allow To check whether Permission is added or not, run - dumpsys package com.emby.embyserver | grep -e "android.permission.MANAGE_EXTERNAL_STORAGE" 1
Luke 42237 Posted January 15, 2025 Posted January 15, 2025 On 1/10/2025 at 10:35 AM, Brainsie said: If you decompile the APK via APK Tool you can see that the manifest doesn't include the Manage_External_Storage. I tried to add it myself, but the APK then doesn't work after I launch it. Can the dvelopers add the following line to the manifest? <uses-permission android:name="android.permission.MANAGE_EXTERNAL_STORAGE"/> Where did you get the apk from? Because i can see other permissions are also missing from the manifest.
alok1 14 Posted January 16, 2025 Posted January 16, 2025 14 hours ago, Luke said: Where did you get the apk from? Because i can see other permissions are also missing from the manifest. What other permissions do you find missing? He didn't give full screenshot of the manifest, so you can't see every permission mentioned in the manifest.
Luke 42237 Posted January 16, 2025 Posted January 16, 2025 13 hours ago, kakashi55 said: What other permissions do you find missing? He didn't give full screenshot of the manifest, so you can't see every permission mentioned in the manifest. Actually sorry, maybe there aren't others missing. Please supply a full screenshot of the manifest. And again, where are you getting the apk from?
alok1 14 Posted January 16, 2025 Posted January 16, 2025 (edited) 20 minutes ago, Luke said: Actually sorry, maybe there aren't others missing. Please supply a full screenshot of the manifest. And again, where are you getting the apk from? From Emby GitHub repo, I always download latest version. Edited January 16, 2025 by kakashi55
Luke 42237 Posted March 12, 2025 Posted March 12, 2025 OK please try again with the latest release and let us know how things compare. Thanks.
