Luke 42245 Posted November 20, 2022 Posted November 20, 2022 Hi, Are you still having an issue with this?
80srule 33 Posted November 20, 2022 Author Posted November 20, 2022 (edited) Yes, but only if it connects through IP V6. If I manually login and headed that way so that it doesn’t ever log out then it’s always fine. I have a few friends that I share with and only one has a problem. The rest of them don’t. The one person that didn’t have a problem from home he can’t login without doing it manually. But just to try and see if he did it from the hotel the last time you went and it came right up. I it’s weird it’s like it can’t support the IP V6 but it’s as though the router is not falling back to the other in order to connect on some and on others it is. The mobile version connects always without IPv6. I just wish that it didn’t run slower but at the end of the day once you’ve connected once and you said it to always remember, then it’s fine Edited November 20, 2022 by 80srule
Luke 42245 Posted November 20, 2022 Posted November 20, 2022 Quote I just wish that it didn’t run slower but at the end of the day once you’ve connected once and you said it to always remember, then it’s fine I would try again with the latest version: https://emby.media/emby-for-android.html
