Zumokishiari 1 Posted September 11, 2022 Posted September 11, 2022 Hello, I've just installed Emby and I'm having a lot of problems with buffering in all video quality options. I've changed a lot of options in even from a perspective of using a specific "Transcoding temporary path" in order to assist, but nothing seems to work. This is in a local network, unfortunately I do believe that hardware can't handle the transconding but at lower quality it should go smooth. OS: # lsb_release -a No LSB modules are available. Distributor ID: Linuxmint Description: Linux Mint 20.3 Release: 20.3 Codename: una PC hardware and logs attached to the topic. Any help would be much appreciated. embyserver.txt ffmpeg-transcode-1d91624b-5e99-426f-9723-2b38cf3e9cb3_1.txt mySpecs.html
RanmaCanada 502 Posted September 13, 2022 Posted September 13, 2022 Greyhound.2020.2160p.ATVP.WEB-DL.DDP5.1.Atmos.HEVC You are attempting to transcode a 4k HEVC file to SDR. You need serious hardware to do this in software mode. If the laptop listed is your server, it is no where near powerful enough to handle this. If you are in the USA, I would recommend you pick up this machine as it will be more than powerful enough to handle pretty much anything. Your other option, is to buy a device that can direct play your files, like a 4k firestick or "other" android box, like the cheap ones from China (they do not support any legal services though and firmwares can be a disater waiting to happen)
Zumokishiari 1 Posted September 13, 2022 Author Posted September 13, 2022 @RanmaCanada Thank you reply. I'm reusing some old hardware I have at home. I know is not the greatest, so to run 4K movies I will need to have a new hardware so that it can handle the 4k movies?
RanmaCanada 502 Posted September 14, 2022 Posted September 14, 2022 On 13/09/2022 at 04:07, Zumokishiari said: @RanmaCanada Thank you reply. I'm reusing some old hardware I have at home. I know is not the greatest, so to run 4K movies I will need to have a new hardware so that it can handle the 4k movies? If you are going to transcode, yes. Your other option is to repalce whatever devices you are using to watch the content on, with ones that can direct play 4k, or if you already have such hardware, stop watching 4k content on devices that absolutely can not direct play it. I personaly have a 4k library, with HDR and DolbyVision separate. The only people who can access these libraries are people who can direct play said content with no transcoding taking place (some have access to just the HDR, some have access to both, pending on their TVs). My "server" can handle any transcodes and tone mapping (except for DolbyVision as it's not possible, yet), but I'm of the mind that 4k should NEVER, EVER be transcoded.
Luke 42237 Posted September 15, 2022 Posted September 15, 2022 I see you're using a browser on Windows. You may want to check out our Emby Theater app for Windows: https://emby.media/emby-theater.html This will allow you to play a broad range of video formats without any server transcoding, which the browser cannot do.
Zumokishiari 1 Posted September 16, 2022 Author Posted September 16, 2022 All my TV at home have 4K natively, my question does Emby knows that the end device has 4K and doesn't need to transcode or that is done at a server level?
Luke 42237 Posted September 16, 2022 Posted September 16, 2022 7 hours ago, Zumokishiari said: All my TV at home have 4K natively, my question does Emby knows that the end device has 4K and doesn't need to transcode or that is done at a server level? Yes it does, but in your example, it was transcoding due to firefox not supporting the video format, so nothing to do with 4K resolution. That's why I would suggest checking out our Emby Theater app as it can direct play more formats without transcoding than the browser can.
Zumokishiari 1 Posted September 17, 2022 Author Posted September 17, 2022 The TV are having also the same issue, buffering I will provide the logs as soon as I can. 1
RanmaCanada 502 Posted September 18, 2022 Posted September 18, 2022 On 17/09/2022 at 14:38, Zumokishiari said: The TV are having also the same issue, buffering I will provide the logs as soon as I can. What devices are hooked up to the TVs? If no devices, what are the exact make and models of the TV's in question. The more information you bring forward, the easier it is to pinpoint the issue.
Happy2Play 9811 Posted September 18, 2022 Posted September 18, 2022 On 9/17/2022 at 11:38 AM, Zumokishiari said: The TV are having also the same issue, buffering I will provide the logs as soon as I can. Yes specific info and logs for TV playback are need as ffmpeg log in first post only covers FireFox. But if the Client cannot Direct Play, the hardware is not powerful enough to convert fast enough at least HEVC conversions. fps=6.1 speed=0.248x
Luke 42237 Posted September 20, 2022 Posted September 20, 2022 On 9/16/2022 at 11:24 AM, Luke said: That's why I would suggest checking out our Emby Theater app as it can direct play more formats without transcoding than the browser can. @Zumokishiari this will likely resolve your issue.
Zumokishiari 1 Posted September 22, 2022 Author Posted September 22, 2022 (edited) @LukeThis a LG Smart TV (43UM7100PLB) and the other one is LG Smart TV (50UN74006LB) with 4k native and it doesn't budge. I'm using the Emby app in WebOS store, is there a way to connect that I'm not aware of to use instead of the app? Another thing you mentioned Emby Theater for PC usage and for TV the same? It shouldn't since they have 4k native and needless for transcoding, I'm assuming things wrong? ffmpeg-transcode-1a3f6c8e-940f-4842-942d-2b5d5c8e20c8_1.txt ffmpeg-transcode-2df6c462-c0d9-4c09-93ff-d7db4168753b_1.txt ffmpeg-transcode-6da09e77-4f94-4ce1-a6aa-55e0ff40d956_1.txt ffmpeg-transcode-7be6acf7-534a-480d-a4bd-9fc132056841_1.txt ffmpeg-transcode-9c1fb420-d4c0-4ad2-b4f1-cab2999db820_1.txt ffmpeg-transcode-350d41ba-514b-4d1c-b571-74f98dd7b3af_1.txt ffmpeg-transcode-786f9636-3504-4d06-931f-05238d4c97b4_1.txt ffmpeg-transcode-68800ff8-f7a3-45fc-a93d-adce4ba14d05_1.txt ffmpeg-transcode-98158639-f4be-46f2-b38d-91ed7178e566_1.txt ffmpeg-transcode-a1cb6cb8-a11b-4beb-8306-ce9a11aeb424_1.txt ffmpeg-transcode-a33a9482-2f50-4cd5-8cb9-c73831f6f0b5_1.txt ffmpeg-transcode-e22297ca-14b9-4d84-931a-29547f7c9248_1.txt ffmpeg-transcode-eaca3d1a-d8be-48bb-be72-2bf54e1b49b5_1.txt embyserver.txt Edited September 22, 2022 by Zumokishiari more information
rbjtech 5341 Posted October 6, 2022 Posted October 6, 2022 Both of those TV's are 4K HDR capable. You need to get the LG Emby client to direct play - ANY other transcode or even a remux is going to stall your system. All the above logs are transcode logs - meaning things are going to fail for you. Also - when testing - ensure subtitles are turned off.
