Riezel 34 Posted September 11, 2022 Posted September 11, 2022 as title says, i have question regarding how premiere works it says 25 devices, from what i heard it was devices that "uses" premiere feature that marked as that "used devices" now my question is, let say i have 5 devices currently registered in emby check server then after several days, the only "active" device that using premiere feature is 3 devices (let say my 2 last registered devices is stolen / broken, and it can't ever again has an access to my premiere server) so in the end, are my "current" registered device is still 5 or reduced to 3?? if it's still 5, is there a way to reduce it to 3 (since 2 device is totally gone now) or need to wait specific time to get those number reduced (from 5 to 3) or it's totally impossible to make it 3 device (stay to 5 forever) * i'm currently using the monthly one
pwhodges 2025 Posted September 11, 2022 Posted September 11, 2022 Devices time out from the count after a period of non-usage, thought to be about a week if I recall aright. Paul 1
Riezel 34 Posted September 11, 2022 Author Posted September 11, 2022 1 minute ago, pwhodges said: Devices time out from the count after a period of non-usage, thought to be about a week if I recall aright. Paul thanks for the reply this will clear all of my schema plan without worries then, thanks again
ebr 16307 Posted September 13, 2022 Posted September 13, 2022 PW is correct. If the device is not used for 7 days, it will no longer be counted. 1
Riezel 34 Posted September 13, 2022 Author Posted September 13, 2022 43 minutes ago, ebr said: PW is correct. If the device is not used for 7 days, it will no longer be counted. alright, thanks for the official confirmation
