roaku 842 Posted September 10, 2022 Posted September 10, 2022 I have a script for converting ts to mkv and would like Emby to run it after all recordings. The script is doing exactly as I want when I run it as the emby user in a terminal. But when Emby tries to run it after a recording, it fails with a 127 exit code. Here are my settings: Excerpt from the log: Quote ... 2022-09-10 14:57:06.787 Info LiveTV: Running recording post processor /bin/bash /volume1/emby_scripts/to-mkv.sh "/volumeUSB1/usbshare/DVR/The Dark Crystal (1982)/The Dark Crystal (1982).ts" ... 2022-09-10 14:57:07.458 Info LiveTV: Recording post-processing script completed with exit code 127 ... Copying the command from the log and running it as the emby user works fine over ssh: sudo -u emby bash /bin/bash /volume1/emby_scripts/to-mkv.sh "/volumeUSB1/usbshare/DVR/The Dark Crystal (1982)/The Dark Crystal (1982).ts" Anything obviously wrong with the settings or something else? Thanks.
Solution TMCsw 259 Posted September 10, 2022 Solution Posted September 10, 2022 Post processing application should be: /volume1/emby_scripts/to-mkv.sh Post processor command line arguments should be: "{path}" also the very first line in your .sh should be: #!/bin/bash if that doesn't work try adding unset LD_LIBRARY_PATH to your script before any ffmpeg commands (only needed once) 1
roaku 842 Posted September 11, 2022 Author Posted September 11, 2022 Thanks @TMCsw Fixing the UI settings + unsetting LD_LIBRARY_PATH did the trick.
softworkz 5133 Posted September 11, 2022 Posted September 11, 2022 9 hours ago, TMCsw said: unset LD_LIBRARY_PATH to your script before any ffmpeg commands (only needed once) Correct. But only for running a system-installed ffmpeg. In cases where you want to use the emby-included ffmpeg you must not unset LD_LIBRARY_PATH.
