phunzie 42 Posted September 10, 2022 Posted September 10, 2022 while doing a media update, E4K crashed....and then every time i restarted E4K it would hang on "updating media"...so i completely deleted E4K and reinstalled (7.7.8), but i still can't get my media to import....when i go to add libraries, i see "All", but not the individual media types (Movies, TV, Music), and even if i select All, nothing gets imported and E4K locks up how can i do a completely clean reinstall of E4K?
quickmic 1709 Posted September 11, 2022 Posted September 11, 2022 11 hours ago, phunzie said: while doing a media update, E4K crashed....and then every time i restarted E4K it would hang on "updating media"...so i completely deleted E4K and reinstalled (7.7.8), but i still can't get my media to import....when i go to add libraries, i see "All", but not the individual media types (Movies, TV, Music), and even if i select All, nothing gets imported and E4K locks up how can i do a completely clean reinstall of E4K? Please sen me a log for review. There is an option called factory reset in plugin config menu. You can also remove following data (Kodi must be stopped): kodi/data/userdata/addon_data/plugin.video.emby-next-gen/* kodi/data/userdata/Database/My* kodi/data/userdata/Database/emby* kodi/data/userdata/Database/Textu*
phunzie 42 Posted September 11, 2022 Author Posted September 11, 2022 finally got it working again after manually deleting the files you mentioned..."Factory Reset" did not work....the plug-in kept getting stuck at "Processing Updates"...maybe the connection to Emby server was screwed up, although it seemed to log-in OK have also sent you logs from before issue was resolved 1
quickmic 1709 Posted September 12, 2022 Posted September 12, 2022 Thanks for the log, I see the issue and will try to cover them in next version.
