martincwd 2 Posted September 9, 2022 Posted September 9, 2022 Following a recent Firefox browser update (now at v.104.0.2 64bit) I've been experiencing problems browsing Emby. When viewing the EMBY homepage after login, the usual 'top of the screen' Navigation options and swtiches do not render and display correctly. Although present and active, they do not show against the black background of the web page. I've checked this problem on two separate desktops (Windows 10 and 11) and the problem is reproducable. It doesn't appear to be affected by the Browser Theme setting and when you view using a MS Edge then EMBY renders correctly with all the icons/switches etc. visible. Has anyone else noticed this problem? Thanks. 1
Luke 42240 Posted September 11, 2022 Posted September 11, 2022 Hi there, can you please show a screenshot example? Thanks.
