bandit8623 226 Posted September 9, 2022 Posted September 9, 2022 (edited) 2.0.79g on amazon and 2.0.80g on nvidia . audio on live tv is delayed. works fine on the windows app. tried direct play also tried transcoding. other movies and tv shows have no delay. Edited September 9, 2022 by bandit8623
ebr 16337 Posted September 9, 2022 Posted September 9, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
bandit8623 226 Posted September 13, 2022 Author Posted September 13, 2022 On 9/9/2022 at 9:03 AM, ebr said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. looks like i was mainly the shield. maybe the last update. i had to a delay on the video 120ms. never had to that before, but it looks like its consistent accross all apps. my bad 1
bandit8623 226 Posted September 28, 2022 Author Posted September 28, 2022 after the hotfix 2 i was able to put audio delay back to 0. 2
