dexus 27 Posted October 24, 2022 Posted October 24, 2022 That's weird.. Just tried it on an episode that I know works on Chromecast.. didn't work on my LG app.. running 35.. It came out in April.. was intro skip even released yet back then?
dexus 27 Posted October 24, 2022 Posted October 24, 2022 Oh.. I use the native one.. that's probably it.. I figured the native one will be most stable over time, and server versions.. seems the plugin works better...
Luke 42234 Posted December 26, 2022 Posted December 26, 2022 Emby for LG TV's 1.0.37 has been released. Stay tuned to the blog for the release announcement. Can you please try out the new update and let us know how it compares? Thanks !
skooogis 7 Posted January 4, 2023 Posted January 4, 2023 On 12/26/2022 at 6:12 PM, Luke said: Emby for LG TV's 1.0.37 has been released. Stay tuned to the blog for the release announcement. Can you please try out the new update and let us know how it compares? Thanks ! Still no announcement?
Luke 42234 Posted January 4, 2023 Posted January 4, 2023 39 minutes ago, skooogis said: Still no announcement? https://emby.media/community/index.php?/blogs/entry/551-emby-for-lg-1037-features-intro-skip-lyrics-rtl support/
pepinacosplus 6 Posted March 15, 2023 Posted March 15, 2023 Im having the same problem after installing a fresh server. Its a emby fault not a LG fault, playback was fine before the reinstall and now some users are getting black screen with HEVC content.
pepinacosplus 6 Posted March 15, 2023 Posted March 15, 2023 ¿anyone managed to resolve this issue? thanks.
pepinacosplus 6 Posted March 15, 2023 Posted March 15, 2023 here's a log if it can help. embyserver.txt
SamES 1084 Posted March 15, 2023 Posted March 15, 2023 14 hours ago, pepinacosplus said: Im having the same problem after installing a fresh server. Its a emby fault not a LG fault, playback was fine before the reinstall and now some users are getting black screen with HEVC content. What's the playback method (DirectPlay,DirectStream,Transcode)? Any ffmpeg logs?
pepinacosplus 6 Posted March 15, 2023 Posted March 15, 2023 Its configured in Direct Play and i do not have any ffmpeg log. Tested in 3 LG TV's but diferent models. OLED65C26LD OLED55B16LA OLED65B16LA Thanks.
Luke 42234 Posted March 16, 2023 Posted March 16, 2023 1 hour ago, pepinacosplus said: Its configured in Direct Play and i do not have any ffmpeg log. Tested in 3 LG TV's but diferent models. OLED65C26LD OLED55B16LA OLED65B16LA Thanks. Can you provide a sample video for testing? Best guess is that it's trying to direct play a variation of hevc that the TV does not support. Currently the app just treats hevc as all or nothing in terms of direct play vs transcoding, but really it needs to evaluated for all of the different hevc profiles so that it's not trying to direct play something that the TV can't handle. That's something that we are looking at for the next app update.
pepinacosplus 6 Posted March 16, 2023 Posted March 16, 2023 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5.1@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 23 min 55 s Bit rate : 1 207 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.024 Stream size : 207 MiB (92%) Default : Yes Forced : No Título 1080p HEVC Códec HEVC Perfil Main Nivel 153 Resolución 1920x1080 Relación de aspecto 16:9 Entrelazado No Cuadros por segundo 23,976 Tasa de bits 1 mbps Profundidad de bits8 bit Formato de píxel yuv420p Fotogramas de referencia 1 ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 42 min 26 s Bit rate : 4 965 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.100 Stream size : 1.47 GiB (92%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Título 1080p HEVC Códec HEVC Perfil Main Nivel 120 Resolución 1920x1080 Relación de aspecto 16:9 Entrelazado No Cuadros por segundo 23,976 Tasa de bits 5 mbps Color primario bt709 Espacio de color bt709 Transferencia de color bt709 Profundidad de bits 8 bit Formato de píxel yuv420p Fotogramas de referencia 1 those can be 2 examples of videos that doesnt work. As i said, same videos worked perfectly in the same TV's before re-installing a fresh server.
