justpig 27 Posted September 8, 2022 Posted September 8, 2022 Hello, I recently visited a relative and logged in to Emby Theatre, I did not remember to logout. Is there a way to revoke that login, I tried changing my Emby Connect password, but it did not affect my current Emby Theatre login, so I can assume that it has not affected the instance at my relatives house. Would greatly appreciate any assistance. Thanks.
Solution seanbuff 1356 Posted September 8, 2022 Solution Posted September 8, 2022 12 minutes ago, justpig said: Is there a way to revoke that login On your Server, go to 'Devices' and delete your relative's Emby Theatre device. That should theoretically log you out and prompt for a re-login the next time they open the app on their end.
