Super957 24 Posted September 7, 2022 Posted September 7, 2022 I set in default poster size "little" but this only reduce image/poster in main page, while inside folder remain great. There is the possibility to reduce also in folder/categories ? Thank Hispa
Happy2Play 9812 Posted September 7, 2022 Posted September 7, 2022 Will assume this is a specific client and not server options. As I have never seen these options, I will guess Android specific?
Super957 24 Posted September 7, 2022 Author Posted September 7, 2022 (edited) 37 minutes ago, Happy2Play said: Will assume this is a specific client and not server options. As I have never seen these options, I will guess Android specific? Yes is a client, my friend use FireTV 4MAX so is android 7.0 i think. Hispa P.S. But from my Emby server can I set how to display the posters? Edited September 7, 2022 by Super957
ebr 16337 Posted September 8, 2022 Posted September 8, 2022 Hi. That is just the default. When in any of those views, you can use the "..." menu to choose a different image size.
