elivick3031 5 Posted September 7, 2022 Posted September 7, 2022 Hi Everyone: I've noticed twice now on my Emby Server that under Running Tasks it's doing a media library scan. " Scan Media Library ". It does this every once in a while even when I have not added or deleted any media on my server. Why does it do this? And is there any way to disable this from occurring?
Luke 42186 Posted September 7, 2022 Posted September 7, 2022 Hi, by default it runs on a schedule every 12 or 24 hours.
pwhodges 2025 Posted September 7, 2022 Posted September 7, 2022 There's a per-library setting, about 60% of the way down, that I think controls this: Paul
pwhodges 2025 Posted September 7, 2022 Posted September 7, 2022 Ah - two different things, I presume... Paul
elivick3031 5 Posted September 7, 2022 Author Posted September 7, 2022 Luke - can I disable this? Or is this something that can not be disabled?
Luke 42186 Posted September 7, 2022 Posted September 7, 2022 2 hours ago, elivick3031 said: Luke - can I disable this? Or is this something that can not be disabled? Which of the two above mentioned things do you want to disable?
Happy2Play 9800 Posted September 7, 2022 Posted September 7, 2022 Click on the Task in Scheduled task and you will see their triggers.
elivick3031 5 Posted September 8, 2022 Author Posted September 8, 2022 I would like to disable the media scan from running automatically every 12 - 24 hours. Can you send me a screenshot as to where I can disable this function? Thanks
Happy2Play 9800 Posted September 8, 2022 Posted September 8, 2022 9 minutes ago, elivick3031 said: I would like to disable the media scan from running automatically every 12 - 24 hours. Can you send me a screenshot as to where I can disable this function? Thanks Go to scheduled tasks and click on the task (not the start button) This will open the task to allow you to adjust the task triggers.
ebr 16307 Posted September 8, 2022 Posted September 8, 2022 Hi. The library scan performs necessary operations and should be run periodically. Will you be running it manually?
elivick3031 5 Posted September 8, 2022 Author Posted September 8, 2022 Oh! I didn't know that ebr. I will turn it back on then. Thanks for letting me know. I just found it weird that my media was scanning when I had not added or deleted any media.
