warent 0 Posted September 7, 2022 Posted September 7, 2022 (edited) I use minikube on Ubuntu Server 20.04.3 to run various apps. For example, I'm successfully doing this with nextcloud and bitwarden without any problems. However, trying to get Emby setup has been painful. It is mysteriously refusing connections and I can't figure out where, why, or how to debug. Here's a sample of my services: $ kubectl get svc --all-namespaces NAMESPACE NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE nextcloud nextcloud-service LoadBalancer 10.104.73.135 192.168.49.2 30001:30001/TCP 26h torrent emby-service LoadBalancer 10.108.171.173 192.168.49.2 8096:30002/TCP 19m vaultwarden vaultwarden-bitwarden LoadBalancer 10.109.74.227 192.168.49.2 8080:32750/TCP 8d We can see I have a few different services running. If I do something like `curl 192.168.49.2:30001` then I get back my Nextcloud page--it all works fine and as expected. (I'm writing this to provide evidence that this is not an issue with the kubernetes cluster since it works for multiple other services) But if I try to connect to emby: $ curl 192.168.49.2:30002 curl: (7) Failed to connect to 192.168.49.2 port 30002: Connection refused I can't tell if the logs indicate any problems, but to me it looks okay... 2022-09-07 01:54:13.367 Info Main: Application path: /system/EmbyServer.dll 2022-09-07 01:54:13.553 Info Main: Emby Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-81-generic (buildd@lgw01-amd64-052) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #91-Ubuntu SMP Thu Jul 15 19:09:17 UTC 2021 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system 2022-09-07 01:54:13.553 Info Main: Logs path: /config/logs 2022-09-07 01:54:13.553 Info Main: Cache path: /config/cache 2022-09-07 01:54:13.553 Info Main: Internal metadata path: /config/metadata 2022-09-07 01:54:13.554 Info Main: Transcoding temporary files path: /config/transcoding-temp 2022-09-07 01:54:13.587 Info App: Application version: 4.7.6.0 2022-09-07 01:54:13.590 Info App: Loading assemblies 2022-09-07 01:54:13.610 Info App: File /config/plugins/Emby.XmlTV.dll has version 1.0.8.0 2022-09-07 01:54:13.610 Info App: File /system/plugins/Emby.XmlTV.dll has version 1.0.8.0 2022-09-07 01:54:13.610 Info App: File /config/plugins/MovieDb.dll has version 1.6.2.0 2022-09-07 01:54:13.610 Info App: File /system/plugins/MovieDb.dll has version 1.6.1.0 2022-09-07 01:54:13.610 Info App: File /config/plugins/NfoMetadata.dll has version 1.0.69.0 2022-09-07 01:54:13.610 Info App: File /system/plugins/NfoMetadata.dll has version 1.0.69.0 2022-09-07 01:54:13.611 Info App: File /config/plugins/DvdMounter.dll has version 1.0.0.0 2022-09-07 01:54:13.611 Info App: File /system/plugins/DvdMounter.dll has version 1.0.0.0 2022-09-07 01:54:13.611 Info App: File /config/plugins/OpenSubtitles.dll has version 1.0.31.0 2022-09-07 01:54:13.611 Info App: File /system/plugins/OpenSubtitles.dll has version 1.0.31.0 2022-09-07 01:54:13.611 Info App: File /config/plugins/Emby.PortMapper.dll has version 1.1.8.0 2022-09-07 01:54:13.611 Info App: File /system/plugins/Emby.PortMapper.dll has version 1.1.8.0 2022-09-07 01:54:13.611 Info App: File /config/plugins/AudioDb.dll has version 1.0.15.0 2022-09-07 01:54:13.611 Info App: File /system/plugins/AudioDb.dll has version 1.0.15.0 2022-09-07 01:54:13.611 Info App: File /config/plugins/OMDb.dll has version 1.0.18.0 2022-09-07 01:54:13.611 Info App: File /system/plugins/OMDb.dll has version 1.0.18.0 2022-09-07 01:54:13.611 Info App: File /config/plugins/Tvdb.dll has version 1.3.1.0 2022-09-07 01:54:13.612 Info App: File /system/plugins/Tvdb.dll has version 1.3.1.0 2022-09-07 01:54:13.612 Info App: File /config/plugins/Emby.Webhooks.dll has version 1.0.19.0 2022-09-07 01:54:13.612 Info App: File /system/plugins/Emby.Webhooks.dll has version 1.0.19.0 2022-09-07 01:54:13.612 Info App: File /config/plugins/EmbyGuideData.dll has version 1.0.7.0 2022-09-07 01:54:13.612 Info App: File /system/plugins/EmbyGuideData.dll has version 1.0.7.0 2022-09-07 01:54:13.612 Info App: File /config/plugins/Fanart.dll has version 1.0.13.0 2022-09-07 01:54:13.612 Info App: File /system/plugins/Fanart.dll has version 1.0.13.0 2022-09-07 01:54:13.612 Info App: File /config/plugins/Emby.Dlna.dll has version 1.0.85.0 2022-09-07 01:54:13.612 Info App: File /system/plugins/Emby.Dlna.dll has version 1.0.85.0 2022-09-07 01:54:13.612 Info App: File /config/plugins/MusicBrainz.dll has version 1.0.21.0 2022-09-07 01:54:13.612 Info App: File /system/plugins/MusicBrainz.dll has version 1.0.18.0 2022-09-07 01:54:13.613 Info App: File /config/plugins/Emby.M3UTuner.dll has version 1.0.13.0 2022-09-07 01:54:13.613 Info App: File /system/plugins/Emby.M3UTuner.dll has version 1.0.13.0 2022-09-07 01:54:13.613 Info App: File /config/plugins/Emby.Server.CinemaMode.dll has version 1.0.40.0 2022-09-07 01:54:13.613 Info App: File /system/plugins/Emby.Server.CinemaMode.dll has version 1.0.40.0 2022-09-07 01:54:13.613 Info App: File /config/plugins/BlurayMounter.dll has version 1.0.0.0 2022-09-07 01:54:13.613 Info App: File /system/plugins/BlurayMounter.dll has version 1.0.0.0 2022-09-07 01:54:13.613 Info App: File /config/plugins/StudioImages.dll has version 1.0.3.0 2022-09-07 01:54:13.613 Info App: File /system/plugins/StudioImages.dll has version 1.0.3.0 2022-09-07 01:54:13.660 Info App: Loading Emby.XmlTV, Version=1.0.8.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.XmlTV.dll 2022-09-07 01:54:13.660 Info App: Loading MovieDb, Version=1.6.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MovieDb.dll 2022-09-07 01:54:13.660 Info App: Loading NfoMetadata, Version=1.0.69.0, Culture=neutral, PublicKeyToken=null from /config/plugins/NfoMetadata.dll 2022-09-07 01:54:13.660 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/DvdMounter.dll 2022-09-07 01:54:13.660 Info App: Loading OpenSubtitles, Version=1.0.31.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OpenSubtitles.dll 2022-09-07 01:54:13.660 Info App: Loading Emby.PortMapper, Version=1.1.8.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.PortMapper.dll 2022-09-07 01:54:13.660 Info App: Loading AudioDb, Version=1.0.15.0, Culture=neutral, PublicKeyToken=null from /config/plugins/AudioDb.dll 2022-09-07 01:54:13.660 Info App: Loading OMDb, Version=1.0.18.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OMDb.dll 2022-09-07 01:54:13.660 Info App: Loading Tvdb, Version=1.3.1.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Tvdb.dll 2022-09-07 01:54:13.660 Info App: Loading Emby.Webhooks, Version=1.0.19.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Webhooks.dll 2022-09-07 01:54:13.660 Info App: Loading EmbyGuideData, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null from /config/plugins/EmbyGuideData.dll 2022-09-07 01:54:13.660 Info App: Loading Fanart, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Fanart.dll 2022-09-07 01:54:13.660 Info App: Loading Emby.Dlna, Version=1.0.85.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Dlna.dll 2022-09-07 01:54:13.660 Info App: Loading MusicBrainz, Version=1.0.21.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MusicBrainz.dll 2022-09-07 01:54:13.660 Info App: Loading Emby.M3UTuner, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.M3UTuner.dll 2022-09-07 01:54:13.660 Info App: Loading Emby.Server.CinemaMode, Version=1.0.40.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Server.CinemaMode.dll 2022-09-07 01:54:13.660 Info App: Loading BlurayMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/BlurayMounter.dll 2022-09-07 01:54:13.660 Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/StudioImages.dll 2022-09-07 01:54:13.660 Info App: Loading Emby.Api, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.Web, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading MediaBrowser.Model, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading MediaBrowser.Common, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading MediaBrowser.Controller, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.Providers, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.Photos, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.Server.Implementations, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.LiveTV, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.ActivityLog, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.Server.MediaEncoding, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.LocalMetadata, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.Notifications, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.Codecs.Dxva, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.660 Info App: Loading Emby.Codecs, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.661 Info App: Loading Emby.Server.Connect, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.661 Info App: Loading Emby.Server.Sync, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.661 Info App: Loading EmbyServer, Version=4.7.6.0, Culture=neutral, PublicKeyToken=null 2022-09-07 01:54:13.805 Info SqliteUserRepository: Sqlite version: 3.35.5 2022-09-07 01:54:13.806 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-8.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_JSON1,ENABLE_MATH_FUNCTIONS,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2022-09-07 01:54:13.806 Info SqliteUserRepository: Opening sqlite connection to /config/data/users.db 2022-09-07 01:54:13.820 Info SqliteUserRepository: Default journal_mode for /config/data/users.db is wal 2022-09-07 01:54:13.899 Info ActivityRepository: Opening sqlite connection to /config/data/activitylog.db 2022-09-07 01:54:13.899 Info ActivityRepository: Default journal_mode for /config/data/activitylog.db is wal 2022-09-07 01:54:13.904 Info SqliteDisplayPreferencesRepository: Opening sqlite connection to /config/data/displaypreferences.db 2022-09-07 01:54:13.904 Info SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is wal 2022-09-07 01:54:13.916 Info App: Adding HttpListener prefix http://+:8096/ 2022-09-07 01:54:13.925 Info NetworkManager: Detecting local network addresses 2022-09-07 01:54:13.925 Info NetworkManager: networkInterface: Ethernet docker0, Speed: -1, Description: docker0 2022-09-07 01:54:13.925 Info NetworkManager: GatewayAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: UnicastAddresses: 172.17.0.1 2022-09-07 01:54:13.926 Info NetworkManager: networkInterface: Ethernet veth5d3d1de, Speed: 10000000000, Description: veth5d3d1de 2022-09-07 01:54:13.926 Info NetworkManager: GatewayAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: UnicastAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: networkInterface: Ethernet veth8837fce, Speed: 10000000000, Description: veth8837fce 2022-09-07 01:54:13.926 Info NetworkManager: GatewayAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: UnicastAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: networkInterface: Ethernet eth0, Speed: 10000000000, Description: eth0 2022-09-07 01:54:13.926 Info NetworkManager: GatewayAddresses: 192.168.49.1 2022-09-07 01:54:13.926 Info NetworkManager: UnicastAddresses: 192.168.49.2 2022-09-07 01:54:13.926 Info NetworkManager: networkInterface: Ethernet veth1b5e7c2, Speed: 10000000000, Description: veth1b5e7c2 2022-09-07 01:54:13.926 Info NetworkManager: GatewayAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: UnicastAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: networkInterface: Ethernet veth2739965, Speed: 10000000000, Description: veth2739965 2022-09-07 01:54:13.926 Info NetworkManager: GatewayAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: UnicastAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: networkInterface: Loopback lo, Speed: -1, Description: lo 2022-09-07 01:54:13.926 Info NetworkManager: GatewayAddresses: 2022-09-07 01:54:13.926 Info NetworkManager: UnicastAddresses: 127.0.0.1 2022-09-07 01:54:13.927 Info NetworkManager: Detected local ip addresses: 192.168.49.2, 172.17.0.1, 127.0.0.1 2022-09-07 01:54:14.055 Info AuthenticationRepository: Opening sqlite connection to /config/data/authentication.db 2022-09-07 01:54:14.056 Info AuthenticationRepository: Default journal_mode for /config/data/authentication.db is wal 2022-09-07 01:54:14.058 Info SqliteItemRepository: Opening sqlite connection to /config/data/library.db 2022-09-07 01:54:14.060 Info SqliteItemRepository: Default journal_mode for /config/data/library.db is wal 2022-09-07 01:54:14.060 Info SqliteItemRepository: cache_size is -98304 2022-09-07 01:54:14.060 Info SqliteItemRepository: page_size is 4096 2022-09-07 01:54:14.821 Info FfmpegManager: FFMpeg: /bin/ffmpeg 2022-09-07 01:54:14.821 Info FfmpegManager: FFProbe: /bin/ffprobe 2022-09-07 01:54:14.821 Info FfmpegManager: FFDetect: /bin/ffdetect 2022-09-07 01:54:14.827 Info Skia: SkiaSharp version: 2.80.0.0 2022-09-07 01:54:14.855 Info TaskManager: Daily trigger for Thumbnail image extraction set to fire at 09/07/2022 02:00:00, which is 5.752403108333334 minutes from now. 2022-09-07 01:54:15.039 Info TaskManager: Daily trigger for Rotate log file set to fire at 09/08/2022 00:00:00, which is 1325.7493471433334 minutes from now. 2022-09-07 01:54:15.048 Info App: ServerId: 9e7da054b6b14113989d7a87f04839c6 2022-09-07 01:54:15.098 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2022-09-07 01:54:15.167 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.0690021 seconds 2022-09-07 01:54:15.167 Info App: Starting entry point Emby.Server.Implementations.Networking.RemoteAddressEntryPoint 2022-09-07 01:54:15.168 Info App: Loading data from /config/data/wan.dat 2022-09-07 01:54:15.172 Info App: Entry point completed: Emby.Server.Implementations.Networking.RemoteAddressEntryPoint. Duration: 0.0050947 seconds 2022-09-07 01:54:15.172 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2022-09-07 01:54:15.173 Info App: Loading data from /config/data/connect.txt 2022-09-07 01:54:15.174 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0016387 seconds 2022-09-07 01:54:15.174 Info App: Core startup complete 2022-09-07 01:54:15.174 Info App: Post-init migrations complete 2022-09-07 01:54:15.174 Info App: Starting entry point NfoMetadata.EntryPoint 2022-09-07 01:54:15.174 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.000404 seconds 2022-09-07 01:54:15.174 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding 2022-09-07 01:54:15.176 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.0017484 seconds 2022-09-07 01:54:15.176 Info App: Starting entry point Tvdb.EntryPoint 2022-09-07 01:54:15.176 Info App: Entry point completed: Tvdb.EntryPoint. Duration: 3.23E-05 seconds 2022-09-07 01:54:15.176 Info App: Starting entry point Emby.Webhooks.WebhooksEntryPoint 2022-09-07 01:54:15.180 Info App: Entry point completed: Emby.Webhooks.WebhooksEntryPoint. Duration: 0.00396 seconds 2022-09-07 01:54:15.180 Info App: Starting entry point Emby.Security.PluginSecurityManager 2022-09-07 01:54:15.180 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 3.44E-05 seconds 2022-09-07 01:54:15.180 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2022-09-07 01:54:15.180 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 8.7E-05 seconds 2022-09-07 01:54:15.180 Info App: Starting entry point Emby.Api.ApiEntryPoint 2022-09-07 01:54:15.180 Info App: Entry point completed: Emby.Api.ApiEntryPoint. Duration: 2.24E-05 seconds 2022-09-07 01:54:15.180 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint 2022-09-07 01:54:15.181 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.0010314 seconds 2022-09-07 01:54:15.181 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2022-09-07 01:54:15.182 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0003815 seconds 2022-09-07 01:54:15.182 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2022-09-07 01:54:15.187 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0053083 seconds 2022-09-07 01:54:15.187 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2022-09-07 01:54:15.187 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.000214 seconds 2022-09-07 01:54:15.187 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2022-09-07 01:54:15.188 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0001184 seconds 2022-09-07 01:54:15.188 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2022-09-07 01:54:15.189 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0014348 seconds 2022-09-07 01:54:15.189 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2022-09-07 01:54:15.191 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0021127 seconds 2022-09-07 01:54:15.191 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2022-09-07 01:54:15.191 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0002456 seconds 2022-09-07 01:54:15.191 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2022-09-07 01:54:15.192 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0003554 seconds 2022-09-07 01:54:15.192 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2022-09-07 01:54:15.192 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 8.8E-05 seconds 2022-09-07 01:54:15.192 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2022-09-07 01:54:15.194 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0016913 seconds 2022-09-07 01:54:15.194 Info App: Starting entry point Emby.LiveTV.EntryPoint 2022-09-07 01:54:15.196 Info LiveTV: Loading live tv data from /config/data/livetv/timers 2022-09-07 01:54:15.196 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.0025546 seconds 2022-09-07 01:54:15.196 Info App: Starting entry point Emby.LiveTV.UpgradeChannelOptionsEntryPoint 2022-09-07 01:54:15.197 Info App: Entry point completed: Emby.LiveTV.UpgradeChannelOptionsEntryPoint. Duration: 0.0009471 seconds 2022-09-07 01:54:15.197 Info App: Starting entry point Emby.LiveTV.RecordingNotifier 2022-09-07 01:54:15.197 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 0.00015 seconds 2022-09-07 01:54:15.197 Info App: Starting entry point Emby.ActivityLog.ActivityLogEntryPoint 2022-09-07 01:54:15.200 Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.0026625 seconds 2022-09-07 01:54:15.200 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint 2022-09-07 01:54:15.201 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.000796 seconds 2022-09-07 01:54:15.201 Info App: Starting entry point Emby.Notifications.Notifications 2022-09-07 01:54:15.201 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.000204 seconds 2022-09-07 01:54:15.201 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2022-09-07 01:54:15.205 Info App: SyncRepository Initialize taking write lock 2022-09-07 01:54:15.205 Info App: SyncRepository Initialize write lock taken 2022-09-07 01:54:15.205 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.003545 seconds 2022-09-07 01:54:15.205 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2022-09-07 01:54:15.206 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0016483 seconds 2022-09-07 01:54:15.206 Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint 2022-09-07 01:54:15.206 Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 7.39E-05 seconds 2022-09-07 01:54:15.206 Info App: All entry points have started 2022-09-07 01:54:16.226 Info App: Init BeginReceive on 0.0.0.0 2022-09-07 01:54:16.226 Info App: Init BeginReceive on 0.0.0.0 2022-09-07 01:54:16.226 Info App: Init BeginReceive on 127.0.0.1 2022-09-07 01:54:18.074 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: /bin/ffmpeg -hide_banner -version 2022-09-07 01:54:18.074 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2022-09-07 01:54:18.097 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Process exited with code 0 - Succeeded 2022-09-07 01:54:18.254 Info SoftwareCodecProvider: h264, libx264, x264 Software Encoder, V-E-libx264 2022-09-07 01:54:18.254 Info SoftwareCodecProvider: hevc, libx265, x265 Software Encoder, V-E-libx265 2022-09-07 01:54:18.254 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2022-09-07 01:54:18.254 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2022-09-07 01:54:18.254 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2022-09-07 01:54:18.259 Info SoftwareCodecProvider: h264, libx264, x264 Software Encoder, V-E-libx264 2022-09-07 01:54:18.259 Info SoftwareCodecProvider: hevc, libx265, x265 Software Encoder, V-E-libx265 2022-09-07 01:54:18.259 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2022-09-07 01:54:18.259 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2022-09-07 01:54:18.259 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2022-09-07 01:54:18.275 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 vaencdec -print_format json 2022-09-07 01:54:18.298 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Process exited with code 0 - Succeeded 2022-09-07 01:54:18.385 Info VaapiCodecProvider: Adapter #0: 'Integrated Matrox G200eW3 Graphics Controller' Id:1334 (Driver: , Vendor: Matrox Electronics Systems Ltd.) 2022-09-07 01:54:18.389 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 qsvencdec -print_format json 2022-09-07 01:54:18.410 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Process exited with code 0 - Succeeded 2022-09-07 01:54:18.476 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 nvencdec -print_format json 2022-09-07 01:54:18.485 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Process exited with code 1 - Failed 2022-09-07 01:54:18.750 Info CodecManager: CodecList: Emby seems to understand that it is part of a network and has the bridge IP address: Quote Detected local ip addresses: 192.168.49.2, 172.17.0.1, 127.0.0.1 So yeah I have no clue what the problem is. Any ideas? Edited September 7, 2022 by warent
warent 0 Posted September 7, 2022 Author Posted September 7, 2022 (edited) Looking carefully, the logs do have some strange anomaly: 2022-09-07 01:54:16.226 Info App: Init BeginReceive on 0.0.0.0 2022-09-07 01:54:16.226 Info App: Init BeginReceive on 0.0.0.0 2022-09-07 01:54:16.226 Info App: Init BeginReceive on 127.0.0.1 could this be the problem? I would expect this to say something like this (EXAMPLE) Info App: Init BeginReceive on 172.17.0.1 Info App: Init BeginReceive on 192.168.49.2 Info App: Init BeginReceive on 127.0.0.1 Why is it listing 0.0.0.0 twice? Is this a bug with how it binds to IP addresses in the network? Edited September 7, 2022 by warent
Solution warent 0 Posted September 7, 2022 Author Solution Posted September 7, 2022 Never mind I'm just terrible with computers. Turns out my k8s service configuration was wrong Make sure the selector in your service.yaml matches the selector for your deployment. This is not an emby problem.
