Deihmos 170 Posted October 6, 2014 Posted October 6, 2014 The movie folder is showing up as pictures without a movie inside the folder for any movie with DTS audio. The few movies with AC3 audio are showing up. I know the TV can play back the files natively and even went as far as installing Plex and did not have the same problem. Is there a solution to this?
crashkelly 62 Posted October 7, 2014 Posted October 7, 2014 Hey there, I think you will get better response if you give the guys in the know something to work with. http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/ The above explains gathering up the logs so that they can try to determine what is going on. Thanks CrashKelly
Deihmos 170 Posted October 8, 2014 Author Posted October 8, 2014 (edited) I have given up on DLNA. Does not work right on the PC either. When I try to play anything it just shows the mediabrowser art. Edited October 8, 2014 by Deihmos
pünktchen 1410 Posted October 8, 2014 Posted October 8, 2014 Don't give up! Try the attached dlna profile. You have to put it in: C:\Users\YOUR_USERNAME\AppData\Roaming\MediaBrowser-Server\config\dlna\user and restart MBServer!
Deihmos 170 Posted October 8, 2014 Author Posted October 8, 2014 A lot more of the movies are showing up now. A few of them still just have the folder picture. What is causing the issue?
pünktchen 1410 Posted October 8, 2014 Posted October 8, 2014 For me mkv with vob subtitles are shown as a picture. They are not supported by TVs and MBS! As a workaround you could disable subtitles in the user preferences of the webclient.
Deihmos 170 Posted October 8, 2014 Author Posted October 8, 2014 (edited) The video files play fine when I tried Plex DLNA and if I placed the video on a USB stick and it played fine. I disabled subtitles and now the video shows up. Hopefully this will become more plug and play in the future. Edited October 8, 2014 by Deihmos
