justinrh 267 Posted September 1, 2022 Posted September 1, 2022 Recording status in guide is not consistently shown. I think this started happening in the last update, but can't be certain. It happened again tonight. It was about 6pm when I opened the guide. I scroll forward (right, that is) about 7 hours, select a movie to record. Then I select another movie after the first movie on the same channel to record. Neither show the red record dot. (Opening the movie detail does show that it is still set to record.) A movie I selected yesterday to record today (starts in 5min) does show the red dot. Windows server, 4.7.6.0 using webapp in Edge Emby guide data
Luke 42242 Posted September 23, 2022 Posted September 23, 2022 Hi, can you please show an example? Are you still running into this?
justinrh 267 Posted September 23, 2022 Author Posted September 23, 2022 I think I already gave an example I haven't recorded much since, so no opportunity to tell.
mark-in-dallas 87 Posted September 24, 2022 Posted September 24, 2022 After selecting a show or movie to record, try refreshing the page and it should then show it as set to record
justinrh 267 Posted September 24, 2022 Author Posted September 24, 2022 4 hours ago, mark-in-dallas said: try refreshing the page Indeed I could do that, but that should not be required.
justinrh 267 Posted October 1, 2022 Author Posted October 1, 2022 (edited) @Luke It just happened again. This time in the TV Schedule section. To be sure, it seems this thread is related to all of the issues I've reported where the UI does not update. I was testing the new recording options in server 4.7.7. I created a keyword recording. I start deleting the new recordings at the top. Go do some other stuff in Emby. Come back to Schedule and scroll to the bottom and see more. I cancelled all three, but they remain after the toast said they was cancelled: I switch tab, type this post, go back and they still show. I had to F5 to remove them from the screen. Edited October 1, 2022 by justinrh
justinrh 267 Posted October 26, 2022 Author Posted October 26, 2022 I haven't done this workflow in a while, so I really wouldn't know (and it is random). A quick, simple test of they keyword recording scenario did not display any errant behavior. 1
justinrh 267 Posted December 10, 2022 Author Posted December 10, 2022 I just saw this again (web app). I opened the guide, scroll right a few times to find the next day's stuff, pick a program, click record, click settings, <- button, the program does not show the red dot. Did it twice in a row.
justinrh 267 Posted January 5, 2023 Author Posted January 5, 2023 Just saw it. There is some delay. At first it did not show, then I waited and scrolled left in the guide a bit then I saw the guide appear to refresh and the dot appeared. With the update issues I've reported and seen, there seems to be a global/system update issue since it is not confined to a single point of the UI in a single app.
