Chalklands 27 Posted September 1, 2022 Posted September 1, 2022 (edited) Just started setting up a Synology DS218 NAS I'm having an issue setting up libraries in Emby. I've installed emby server on the Synology and created some folders on volume 1. The data I want to add to emby is in /volume1/Media/Documentaries However, If I open emby server, when I try to add a library this occurs: If I click on 'Folders' to add a folder from the synergy, I can navigate to /volume1 where I can see the 'Media' subdirectories. If I click on 'media', the directory box in emby just goes blank. If I manually add the folder location: /volume1/Media/Documentaries I get the message 'The path could not be found'. Any ideas what I'm doing wrong? The folders have read/write access. Edited September 1, 2022 by Chalklands typo
Chalklands 27 Posted September 1, 2022 Author Posted September 1, 2022 That did the trick. Thanks Luke! 1 1
FrostByte 5454 Posted September 2, 2022 Posted September 2, 2022 3 hours ago, Chalklands said: Cheers Frostbyte! Thanks for reporting back that you got it working.
