jscoys 147 Posted October 5, 2014 Posted October 5, 2014 Hi, When you go in the settings, choosing External Players button, you've got an error message "MediaPlayersPage could not be found" as you can see on the screenshot attached to this post. The application crashes and a message asks to close. My version : 3.0.5391.3178. Tested on 2 different computers, same results. Here's the error message : Here's the log : crash_47429f71-e720-405a-a556-2abdb9583843.txt Thanks for help! 1
elshagon 44 Posted October 6, 2014 Posted October 6, 2014 I have the same problem and error message as you
Luke 42239 Posted October 6, 2014 Posted October 6, 2014 I've pushed a fix. Just install from the website and you should be ok.
jscoys 147 Posted October 7, 2014 Author Posted October 7, 2014 @@Luke : same problem for "Program launcher"
jscoys 147 Posted October 10, 2014 Author Posted October 10, 2014 (edited) @@snazy2000 : could you have a look into this problem please? Edited October 10, 2014 by jscoys
jscoys 147 Posted October 10, 2014 Author Posted October 10, 2014 @@elshagon : Could you confirm that you've got same problem with Program launcher section please?
elshagon 44 Posted October 11, 2014 Posted October 11, 2014 @@elshagon : Could you confirm that you've got same problem with Program launcher section please? I just looked and see that I had removed program launcher from that pc setup. When I go to plugins it doesn't show it installed or listed to install. I'm not sure how to bring it back. I did fix the external player error however by installing MBT again as Luke suggested.
snazy2000 344 Posted October 21, 2014 Posted October 21, 2014 Program launcher should now be fixed. Let me know
