JuJuJurassic 50 Posted August 31, 2022 Posted August 31, 2022 Hi All, Everything was working perfectly with Live TV, ok the EPG wasn't very good,but I just subscribed to an EPG service, but today IPTV doesn't work. I have a HDHome run, which works perfectly. The channel guide is empty and every IPTV channel say no streams are avaliable. It could be the IPTV prrovider, but I noticed a few errors in the log, attached. I've pinged the IPTV provider and it responds, I've pasted some of it's channels URLs into VLC and they work, but I've had problems before with streams. Is there something in the log that can point tot the problem. Any advice to further troubleshoot would be apprechated. Thanks embyserver (5).txt
Luke 42243 Posted September 1, 2022 Posted September 1, 2022 Hi, please try running the refresh guide scheduled task in emby server and see if that helps. Thanks.
